JMB RetrofitsSky Insurance
Results 1 to 11 of 11
    ilim's Avatar
    Nov 2011
    632
    Xenon rear levelling sensor
    After getting my car lowered I think the rear sensor for auto level has broke, as at nights i can only see a few meters infront of me. Is there anyway of checking by looking under the car.
    Does anyone know the location and what it looks like.
    Ilim
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    How do you know it's the rear sensor?
    ilim's Avatar
    Nov 2011
    632
    On my last car, the same had happened mate and the rear is more prone to break after lowering apparently.
    If anyone know both locations, let me know so I can check both.
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    After I lowered mine on coilovers my xenons needed manually adjusting via a screw on the top of each under the bonnet, although mine was the opposite as they were pointing way to high and blinding everyone!
    Edit: Now I think about it, they also had a tablet pc with some audi software plugged in to calibrate them aswell.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    I don't know if I have a front sensor on my car or not because I couldn't see one when putting on my coilovers but mine still point low... The rear sensor is definitely not broken though. I need to manually adjust them as they point about 10 meters in front of the car and you can't see anything at night... Haha. Come over to mine if you wanna adjust them today?
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    27,038
    Check front & rear, front is passenger side & turn wheel full left lock, get torch & look through gap, rear you need to get under car with torch as its hidden up in the rear passenger track arm area, hidden under spare wheel area, but by exhaust as such, handbrake on of course lol.
    Quote Originally Posted by MxGaza33 View Post
    Ye was about to say, you shouldnt use manual adjusters without 1st using vcds to set adjustment mode or it will not be correct.
    Quote Originally Posted by Daggerit View Post
    & again :P
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    What you meaning by the VCDS stuff? Would manually adjusting them not just change the 'static' position of them so they'll still have the same range of motion?
    ilim's Avatar
    Nov 2011
    632
    & again :P
    What does the sensor look like?
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    If its anything like mine it's just a bar connected to the wishbone/suspension and the other end to what looks like a potentiometer...
    ilim's Avatar
    Nov 2011
    632
    Ah, I'll ask Rene to have a look and see what he can do!!
    27,038
    Yes its just a metal bracket fixed to the chassis, that has an arm that can swing up/down with the suspension arms, has a 4 pin connector attached to it with 3 wires inside.
  1. Plug for rear xenon level sensor
    By rob irl tdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2012, 18:42
  2. Xenon Level Sensor Rod Replacement?
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2010, 18:57
  3. Retro-fit rear parking sensors
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2005, 23:47
  4. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  5. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
