Volks AutosEM Tuning
Results 1 to 10 of 10
    Nov 2012
    20
    Heated mirrors and folding not working :-s
    Recently purchased a my09 s3 , it has the factory option of heated mirrors and folding , but for some reason niether are working , can get the glass to move via switch just no heat or fold , any help apreciated , cheers
    A3Kent's Avatar
    Different Gear
    May 2012
    1,024
    How long have you had the car and has either function ever worked in your possession?
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Nov 2012
    20
    No never worked since ive owned it , did they come with the same switch with the options to heat and fold even though there not actually fitted ?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,024
    I wouldn't have thought so. I assume you have the function at the 6 o'clock position on the door armrest to fold the mirrors?
    If you've only owned it for a short time would it still be under warranty?
    Nov 2012
    20
    Ye fold at 6 heated at 12 , no i bought it private and its just over 3 yrs old so out ov audi warrenty, had it plugged into vag com nothing coming up on that
    A3Kent's Avatar
    Different Gear
    May 2012
    1,024
    Are you able to fold the mirrors with you hands quite easily and normally? I haven't tried folding my electric folding ones so wouldn't know what to expect but I suspect it wouldn't be as easy as if they were non electric folding. Be careful!
    Next thing I would check then is the heating connections inside the wing mirror case. If you angle the glass as far down as you can towards the floor, then get your fingers in behind and gently pull the glass off the mount. There should be 2 (i think) connections to the glass, this is the heating aspect.
    Jul 2011
    Not Disclosed
    421
    Doesn't the mirror heating work off the rear screen button in the climate control panel?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,024
    Don't think so, it has it's own switch position on the drivers door where the electric window buttons are.
    Apr 2012
    7
    On an 09 it works off the windscreen de-mist button. You have to have the wing mirror dial at 12 o'clock as well.
    Nov 2012
    20
    Ok so had a look behind my mirror definatly got connections for heated mirror to the glass , tryed it with front demist still not workin , ther is a light last iluminates on dash or not when there switched on isnt there ? Also folded mirrors in by hand they fold in fairly easy dont feel like im pushin a motor if you get me , can i use one of these vin decoders to see if it was definatly fitted from factory ? cheers
  1. Light swich and auto dim mirror inside car not working. A4 avant s-line 2004
    By audimannen in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th October 2011, 13:08
  2. A4 cab 02 Hood and windows not working
    By Dchaos in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2009, 22:28
  3. Interior lights and sunroof not working?
    By wayneharrow in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2008, 17:15
  4. rear sub and speakers not working
    By nick-barnes07 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2007, 08:31
  5. Replies: 0
    Last Post: 25th January 2007, 19:50
