Recently purchased a my09 s3 , it has the factory option of heated mirrors and folding , but for some reason niether are working , can get the glass to move via switch just no heat or fold , any help apreciated , cheers
Ye fold at 6 heated at 12 , no i bought it private and its just over 3 yrs old so out ov audi warrenty, had it plugged into vag com nothing coming up on that
Are you able to fold the mirrors with you hands quite easily and normally? I haven't tried folding my electric folding ones so wouldn't know what to expect but I suspect it wouldn't be as easy as if they were non electric folding. Be careful!
Next thing I would check then is the heating connections inside the wing mirror case. If you angle the glass as far down as you can towards the floor, then get your fingers in behind and gently pull the glass off the mount. There should be 2 (i think) connections to the glass, this is the heating aspect.
Ok so had a look behind my mirror definatly got connections for heated mirror to the glass , tryed it with front demist still not workin , ther is a light last iluminates on dash or not when there switched on isnt there ? Also folded mirrors in by hand they fold in fairly easy dont feel like im pushin a motor if you get me , can i use one of these vin decoders to see if it was definatly fitted from factory ? cheers
