Badger5Monster Motorsport
Results 1 to 7 of 7
    Pepsi's Avatar
    Nov 2012
    Lancashire/Yorkshire
    82
    Smile Starting problems when engine is warm
    Alright ppl.
    I'v got this issue on my 1.9 tdi 8p1. It's been a problem ever since i'v owned the car (18 months).
    The car starts absolutely fine when cold, literally a millisecond after turning over the key. The problem i get is when the engine has been running a long or short while and warmed up, When re-starting, it does start eventually but the turning over seems like a lifetime. I can recall on very few occasions through our rare summer days, If i didn't start the car till afternoon on a hot day i would sometimes get a similar issue with delayed starting.
    Anybody had a similar issue or any idea on the culprit?
    Cheers....
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    this has been a common problem on the 2.0tdi, probably exactly the same on the 1.9.
    Starter Motor is fooked.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by mjr901 View Post
    Correct ! Common problem.
    When hot the ecu tells the fuel management system to provide less fuel ( than when cold) and the starter motor has to work much harder to start the engine.
    Pepsi's Avatar
    Nov 2012
    82
    Ok thats great guys, I shall pur chase a new one. Whats the likelyhood of the engine temperature sensor sending inaccurate readings to the ecu when the engine is hot? This was something suggested from a friend?
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    not impossible, may I suggest you replace the cheapest first.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Pepsi View Post
    If you think about it, the temperature sensor is obviously sending the correct info. when cold as you have no starting problem then.
    If the sensor was faulty wouldn't it still be sending cold info ? It's because it's sending 'hot' info. that the ecu reduces/weakens the fuel input and therefore I doubt it's a problem with the sensor.
    Nov 2012
    57
    Had exactly the same thing with my Mk5 Golf 2.0 TDi (BKD engine) changed the starter with a Bosch unit from Euro Car Parts and it cured the problem.
  1. A6 2000 2.7t - won't start when engine semi warm
    By dan small in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd October 2013, 09:57
  2. starting problem when warm
    By SHAKEY LFC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th August 2012, 17:13
  3. audi S3 starting problem (when warmed up)
    By russelj80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2012, 22:29
  4. APY Starting problem when warm
    By LordNelson in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2010, 09:58
  5. Starting problem after engine mounting bolts snapped
    By VaulterTim in forum Diesel forum
    Last Post: 21st July 2007, 10:11
