AH FabricationsSky Insurance
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Old-Boy-Racer
Thread: Clutch issue - Help needed!
    Sep 2012
    Lichfield
    389
    Hi,
    I am having issues with what I think may be the clutch in my A3, I am having slowly increasing difficulty getting into first and reverse gear and the clutch has started to bite when it is hardly off the floor.
    Anyone know what the issue is, Can anybody help me?
    Thanks, Brad.
    Turbo jay's Avatar
    Leather repair specialist
    Jul 2012
    North west
    550
    I'm pretty sure that when the clutch is going the bite is right at the end on the pedal someone will correct me if I'm wrong, so it sounds to me you have a issue with the master cylinder, my advice would be to get that checked out first! Hope this helps mate
    Sep 2012
    Lichfield
    389
    Quote Originally Posted by Turbo jay View Post
    Thanks bud.
    Im a real noob when it comes to these sort of things I'm afraid.
    Is the master cylinder a big deal? What sort of price to replace? Thanks!
    Turbo jay's Avatar
    Jul 2012
    North west
    550
    No problem mate, no it's not a big deal just a straight swap but you might have to also replace the fluid not sure if it come's with fluid in. just give Tps a ring and find the price or check on eBay
    Stol1975's Avatar
    Sep 2012
    227
    Any updates on this? My car will move in gear without my foot on the gas. I have done the 5th gear pull off from stationary to test the clutch and it does stall. Is this a standard thing?
    Old-Boy-Racer
    The clutch is self adjusting so if this is happening it will probably be a problem with the hydraulic system (master cylinder in engine bay, slave cylinder inside bell housing with clutch, or pipe work connecting them. You need someone with some knowledge to work out which. You can make a start by looking for hydraulic fluid leaks. Any replacement will require a re-bleed.
    it is also not unheard of for the clutch pedal pivot to break away from the pedal box (partial or completely) this might cause your symptoms.
    bugsy likes this.
    Stol1975's Avatar
    Sep 2012
    227
    How serious a problem is this? Is anything getting damaged if I don't get it looked at soon? Thanks in advance for any replies.
    Sep 2012
    Lichfield
    389
    Hi lads, update for you.
    I was low on brake fluid, that is why my clutch was playing up and I had trouble engaging gears.
    If any of you are dumbos like me and having issues with your clutch, check your Blake fluid level!
    Stol1975's Avatar
    Sep 2012
    227
    Haha and how does a dumbo like me check the brake fluid??
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,841
    the reservoir is under the bonnet at the bulkhead! check in your handbook.
    2009 A3 SB 2.0T DSG S line
    Jan 2012
    SW London
    794
    So it was the brake fluid then. Hope ur keeping an eye on it now, cos if it got that low then it could well be leaking from somewhere
    Apr 2013
    Warwickshire
    32
    Quote Originally Posted by BradHatton View Post
    Hi,
    Thanks, Brad.
    i hav this problem jus had a brand new clutch fitted an the butting point is at the floor not allowing me to select gears or even drive unless I start in gear but if I hold e clutch I can feel it tryna drag ,
    A3 1.8t AUG ,
    k03s, ported exhaust
    Weitec coilovers , SMF lightened an balanced
    Just for now
    " fmic " forge 007p"remap
  1. Koni Front coilover issues, Help needed ASAP
    By S3 Paul in forum DPM Performance
    Last Post: 30th January 2012, 17:04
  2. A3 fsi se 2004 clutch vibration help needed
    By Jakal2001 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2010, 22:38
  3. 2.5 tdi poss fueling issue. help needed
    By a4-rob in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th January 2010, 22:05
  4. A3 Idle issue, help needed
    By Crashlanding in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2009, 14:21
  5. MFSW issues - Help needed on programming
    By mattandrew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2008, 22:42
