EM TuningSky Insurance
Results 1 to 8 of 8
    Nov 2012
    14
    Adapter cable LED taillights
    hi,im looking for some info i want to make my own adapter for the led taillights as simple as possible
    I found one on this site but it dont mention if u want the resistors on, were they go
    Basically what i got from that diy is i can just get the plug for the led outers and insert the pins from current plug and for the inners i have to get repair wires cause the pins are smaller in that case and did not found where the resistors go
    Anybody can help me on this?
    Jan 2012
    1,837
    I coulda swore I seen this somewhere before yesterday.
    Do a search!
    Nov 2012
    14
    Quote Originally Posted by A6CR View Post
    Do a search!
    Of course i did and this is the post i was reffering to but dont mention the resistors where they go and i really wanna keep it more simple just swap the cables into the connector
    Done?SB Facelift LEd Tails WITH prefacelift LED harness / cables? Without kufatc?
    Thanks for the help
    Nobody did this mod ?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    I always make up my own looms and dont use resistors when i wire them in and they work perfectly fine
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Nov 2012
    14
    Quote Originally Posted by Ash187 View Post
    And your leds dont flecker or have any error bulb out?
    If not ill try it then without
    Jul 2011
    106
    Re: Adapter cable LED taillights
    Likewise, I made my own looms without resistors and have not had any flickering or bulb errors either. The LED tubes on the inner lamps are connected to my plate lights, which do have resistors installed (non-OEM LEDs,) but the outers do not have resistors in play anywhere and work fine. :thumbup:
    Nov 2012
    14
    anybody know how do i take the wires from the old connector?maybe there is a trick,i want to avoid cutting the old connector if possible,i understand from my readings the pins from old cable is the same for new connector
    I want to have only one plug for each of the lights
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    You need a pin removal tool, or u could use a thin piece of metal to unclip the pin. You need to do it from the front of the connector in the small gap above the hole where the pin end can be seen. It's not easy without a pin removal tool though. As for the inners just cut the ends off and solder on the new repair wires
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  1. A6 Avant LED taillights & VAGCOM IN CENTRAL BELT SCOTLAND!
    By j666nty in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st June 2010, 14:20
  2. Symphony II to RNS-E Adapter cables...
    By a3_dan in forum Satellite Navigation
    Last Post: 7th December 2009, 20:07
  3. Chorus to concert 3 adapter cable
    By Synchromesh in forum In-Car Entertainment
    Last Post: 20th June 2009, 15:12
  4. RNS-e Adapter Cable Question
    By ian ditch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th March 2009, 12:40
  5. CD changer adapter cable to mp3 player
    By auroan in forum In-Car Entertainment
    Last Post: 28th September 2004, 22:36
