    Sep 2012
    Lichfield
    389
    2.0TDi clutch replacement
    Hi,
    I feel my clutch may be on its way out.
    Can anybody recommend a cheap replacement, or even an uprated one if the right price.
    I'm unsure whether it is going, but it seems it.. I'm struggling to get it in and out of 1st and reverse, asif it is getting stuck, also I if I lift the clutch pedal ever so slightly without even touching the accelerator, the car will slowly move..
    Any help appreciated!
    Jan 2012
    SW London
    751
    May not be the clutch mate, i had this problem when my flywheel began to give up on me, struggled to go into gears, had to pump the clutch a few times. U checked ur brake fluid levels? Anyhow, dont skimp out on the clutch if it is that, "buy cheap pay twice". If its the flywheel then look into the single mass flywheel conversions if it takes ur fancy as a new dual mass flywheel is expensive.
    Checkout darkside developments for their SMF kits, i think SACHS do one too
    Sep 2012
    Lichfield
    389
    Quote Originally Posted by Sidhu88 View Post
    Thanks for the response mate, that does sound accurate, although It only does it in and out of reverse. Every other gear seems fine at the mo!
    I don't actually know how to check my brake fluid levels haha :SOS:
    What did you do about it and what sort of money did it set you back if you don't mind me asking?
    Jan 2012
    SW London
    751
    Mine seemed to ease up once warm at first but when it let go completely i was fighting to put it into gear. The kit was around £400 but i had a lot of other work done too so not sure of the cost of just the flywheel and clutch kit labour. Get it to a garage to have it checked anyway cos i may still be wrong it just sounds similar to my problems. Brakefluid reservoir is just to the right of the coolant reservoir
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Sep 2012
    Lichfield
    389
    As said - I think it my just be due to low brake fluid level. I will top it up tomorrow and see if it makes a difference.
    Thankfully today I have had absolutely no issue with the clutch or gears, so I'm pretty certain it is the brake fluid.
  1. Clutch replacement on TDi 130 - dual mass flywheel as well?
    By AndyMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th May 2008, 20:44
  2. audi 2.7T clutch replacement (A6)
    By aznflame in forum General Technical / How To
    Last Post: 3rd August 2007, 12:06
  3. Clutch Replacement On S3
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2007, 21:46
  4. V6 quattro clutch replacement...
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd February 2006, 17:23
  5. A4 1.9 tdi - flywheel clutch replacement ?
    By joncat in forum Diesel forum
    Last Post: 24th May 2004, 21:06
