Badger5Volks Autos
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By olethalb
Thread: Which Diverter Valve
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    With 45k miles on the clock of my 2009, 2.0 TFSI Quattro with AUX engine code A3, I'm thinking about changing the Rev G (06 F145 710 G, Diaphragm with Blue Seal) DV valve.
    A few days ago read an article on this, but bugger me if I can find it now.
    Can someone please advise which replacement Rev versions I can use and where to buy online, original, oem, or other types.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    I've got a Forge 007 in mine fitted by JBS in Sheffield. Sweet as a nut.
    jaydav2306's Avatar
    You want the Rev D from Audi
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    shady-ninja's Avatar
    854
    what is rev D?
    Quote Originally Posted by jaydav2306 View Post
    jaydav2306's Avatar
    Revision D, I think its the latest and greatest, I changed mine and instantly noticed a difference, best £55 spent
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Ta for the replies guys. Bought a Rev D from GSF for £46 inc VAT and free delivery.
    olethalb's Avatar
    Aug 2012
    314
    i though 'G' was the latest and greatest, i have a D and am certain it leaks. i can't see how the plastic piston makes a seal either
    Sep 2012
    Grimsby, Lincolnshire
    72
    Quote Originally Posted by olethalb View Post
    the same way your piston rings seal against the cylinder bore.
    jaydav2306's Avatar
    If you ask for the latest revision of this DV they will give you a D
    Sep 2012
    72
    There are two parts to the DV part numbers you need to look at.
    The main revision is to do with the 3rd character..
    06F145710 is the old parts (diaphragm)
    06H145710 are the newer parts (piston)
    B/C/D/G at the end refers to minor revisions.
    olethalb's Avatar
    Aug 2012
    314
    Quote Originally Posted by nick9one1 View Post
    It does not have sprung steel rings
    plastic against ally doesn't make for a great airtight seal against 25 psi, i was doing a lot of reading up into the best one to have. i bought a forge DV and hated it so went and bought a 'D' revision and i can hear it leaking back into the TIP so googled the hell out of it and seems 'G' gives the better seal. one of the tuning companies reported issues with the 'D' as well....
    Tezgreig likes this.
    Sep 2012
    72
    I said 'the same way your piston rings seal against the cylinder bore'
    Its not that difficult to understand...
    Engine - Pison/ Piston ring/ Cylinder bore
    DV - Piston/ rubber o-ring/ DV bore
    The forge one works in the same way - rubber o-rings.
    I cant see why you don't like the Forge one? I fitted one instead of the stock rev.C valve and its much better. You cant even tell I have it installed.
    olethalb's Avatar
    Aug 2012
    314
    my D has no rubber O ring which is why i am struggling to grasp how PLASTIC seals sufficiently to ally, i'm well aware of how a piston inside the engine works thanks for the breakdown.
    lack of post count does not equal lack of knowledge.....
    the forge one caused turbo stall and the chatter sound no matter what spring, ordered a new piston and service kit, ensured 4mm ID vac line was all new and secure but still did not release boost properly. sounded good but not healthy for my new turbo.
    olethalb's Avatar
    Aug 2012
    314
    quick google....Volkswagen OEM Diverter Valve Upgrade | my-gti.com
    interesting feedback
  1. Diverter valves - which way
    By adidasandy in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2012, 09:07
  2. Which is best a standard rev D or forge uprated diverter valve for stage 2+
    By brough74 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th January 2011, 11:44
  3. Which diverter valve?
    By 98 A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th July 2007, 03:45
  4. which diverter valve do i get
    By turboaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2007, 10:48
  5. which diverter valve?
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 22:41
