EM TuningAH Fabrications
Results 1 to 14 of 14
    Nov 2012
    57
    Bootlight doesn't work
    After owning the car for two days i have only just noticed the boot light doesn't work.
    Changed the bulb - no joy
    Checked all the fuses - all ok
    One thing i have noticed and it may be unrelated is the central locking will kick in after 30-60 seconds when the boot is open. I had a similar issue with an old Mk4 Golf and if i remember correctly it was water ingress from the rear washer jet which had corroded the micro switch in the lock.
    Any thoughts. Could it be time for a new boot loch mechanism?
    Lewis583's Avatar
    Mar 2010
    834
    Does the vehicle register that the bootlid is open in the DIS?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Nov 2012
    57
    It does
    Lewis583's Avatar
    Mar 2010
    834
    Check for a feed to the bulb would be my next step
    Full VCDS
    Nov 2012
    57
    I'm working from home tomorrow so will chase the loom back as far as i can. Damn
    Lewis583's Avatar
    Mar 2010
    834
    Don't need to, Take the bulb out and put a voltmeter between the terminals, one will read 12v the other 0volts. If you have 12volts at the holder, it's either poor connection between bulb & holder/poor earth/dodgy new bulb(not unheard of)
    Full VCDS
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,626
    The interior lights are on a timer, so if the DIS thinks the boot has been open past the allotted time wouldn't it switch the light off anyway??
    2009 A3 SB 2.0T DSG S line
    Jan 2012
    1,615
    Make sure the bulb is in the correct way and touching both contacts on top and below the bulb itself.
    Fossie
    Rhubarb Triangle
    3,961
    Microswitch in boot lock !
    Disconnect bootlock and see what happens. If nothing happens then connect the two contacts together. Check on the DIS each time to see if warning has gone out.
    Lock mechanism should work immediately, not after so many seconds !
    Nov 2012
    57
    Hi Mike
    the central locking works as it should but if you unlock the car and open the boot after 30 seconds the car locks itself.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    I had that problem. Replaced the bulb holder and all back to normal. Costs around £12 delivered from Stoke Audi.
    VCDS USER
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by Strangely Brown View Post
    Hi Mike
    If you unlock the car and leave it, it locks itself automatically again after about 30 seconds. This is normal.
    If you unlock the car and then open the boot and it locks automatically again after 30 seconds then the control module is being told that the boot is locked - if you see what I mean !
    The microswitch in the boot lock is not operating correctly for whatever reason. I should try taking it out and blasting it with WD40 or similar or better still, dismantle and clean.
    It does sound like a water ingress problem so might be worth having a look at the wiper motor as well.
    Nov 2012
    57
    Thanks Mike. I'm confident it is lock related so weather depending i will be removing it this weekend.
    Nov 2012
    57
    After some effort i removed the boot trim and the rear wiper motor is leaking plus there are signs of corrision on the boot catch mechanism so i think i've found the issue!
    New parts ordered today off ebay (Lincoln Audi) for just over £100 for both including postage.
  1. wiper doesn't work :(
    By Amir in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd May 2010, 15:58
  2. Diesel gauge doesn't work properly. What should I do?
    By ntp in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th October 2009, 21:22
  3. Instant email notification doesn't work after AS.net upgrade???
    By Dennis Moeller in forum Site Support & Announcements
    Last Post: 15th July 2009, 15:33
  4. one of my headlights doesn't work on my s3
    By nath-w in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2009, 00:23
  5. afterrun mod doesn't work???
    By electricracer in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th September 2008, 15:23
