JMB RetrofitsEM Tuning
Page 2 of 2 FirstFirst 12
Results 41 to 63 of 63
Like Tree4Likes
Thread: OEM LED Numberplate Lights without errors 2010+
  1. #41
    Mar 2013
    they appear to be working now!
    no bulb out errors on my 2012 A3 quattro
    They are not that bright either - but noticably brighter than the OEM halogen
    Will report back in a while - going on a longer drive this evening
  3. #42
    Nov 2012
    Bournemouth
    37
    Mine arrived today but bring up a DIS error as soon as the sidelights are switched on, mines a 2010 :-( What's also odd, is when I switch my lights on, for a split second, I get an error first about my rear right light but its working? When I had the A5 LEDs installed, I would also get this error? I wonder why mine aren't working but yours are on both a 2010 and 2012? Any ideas?
    drew306 likes this.
  4. #43
    Nov 2012
    Bournemouth
    37
    Quote Originally Posted by MilkDawg View Post
    Figured out the rear light warning. The previous owner had fitted the wrong bulb, less wattage, causing the random warning every now and then. Still no clue with the LED number plate lights though.
  5. #44
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,424
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Hey dude,
    What spec is you car and have you changed any of the coding to turn off cold monitoring etc?
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi A3 For Sale: 2011 Audi A3 1.8TFSI Black Edition. Low Mileage. Great Condition. Manuf Warranty
    http://www.audi-sport.net/vb/sale-wanted-audi-cars/219560-sale-2011-audi-a3-1-8tfsi-black-edition-low-mileage-great-condition-manuf-warranty.html
  6. #45
    Nov 2012
    Bournemouth
    37
    Hey Cruiser,
    Its a 2010 3 door 170 TDI. That's a good point actually. I think it was ticked when I tried to fit the A5 LEDs but I think I unticked it again when it didn't work, as my CE is too low for the coding to take effect. I can double check tomorrow, do you think that could cause it?
    Thanks for your reply.
  7. #46
    Nov 2012
    Bournemouth
    37
    So, checked my settings and it isn't selected in VCDS, so not sure what to try now :-(
    Emailed the seller who said would send another set but I don't think that will help TBH.
  8. #47
    Mar 2013
    Quote Originally Posted by bulldog a3 View Post
    working fine for me still
  9. #48
    TDI140's Avatar
    May 2011
    1,327
    How come you took such a hard approach, i just bought some off ebay a guy called LED lighting with built in canbus error resistors and they have been working for over a year no problems and no extra wring needed just plug n play
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
  10. #49
    Nov 2012
    Bournemouth
    37
    2010 cars seem to be a problem for LED number plates. DIS errors for just about all bulbs.
  11. #50
    Nov 2012
    Bournemouth
    37
    Ok, update. I emailed the seller and explained that they still produce an error on the DIS, I just received a replacement set today and NO ERROR! The replacement set were exactly the same as before, so looks like they were just faulty. Will report in a few weeks or so but so far, no errors on my 2010 8P, with no changes via VCDS.
  12. #51
    Feb 2013
    Hello
    2010 8PA Manufactured in Apr.
    Ordered it from the e-bay seller and installed.
    No ERROR in the DIS but the housing of the new light where it clips to the rear lid is bit thinner than OEM
    So it falls even with the bolts tightened.
    I have added couple layers of tape to the new LED housing and it fits and sits perfectly at the rear lid.
  13. #52
    Nov 2012
    Bournemouth
    37
    I seem to have another weird issue. If i start the car and then switch lights on, no error. If i switch lights on first, then start the car, i get a number plate bulb error. Switch engine off, turn lights off, start car, lights back on, no error! Can someone with a set of these and a 2010+ please try this for me?
  14. #53
    Feb 2013
    I'll try
  15. #54
    Feb 2011
    Preston
    64
    Hi mate,
    I am sure I don't get these errors and this is on a 2010 A3.
  16. #55
    downtothebone's Avatar
    Mar 2012
    Wimbledon
    202
    Works fine for me either way - December 2010 car with the BCM615 module which is the problem.
    APR Carbonio CAI / Eibach ARBs / BCS 3" Downpipe & Sports Cat / H&R 50mm Springs / APR Stage 2 / WALK / Forge Quickshift / RNSE / Forge 330 Big Brake / Carbon Grab Handles / Whiteline F&R Adj Drop Links / R8 Oil Cap / Porsche Coolant Cap / APR Intercooler
  17. #56
    Arjuanamo's Avatar
    4300K
    Apr 2012
    London
    110
    The OEM A5 ones used to bring up an error on my DIS until i changed the coding in VCDS(Byte 17 bit 7).My friends who have 2010 and 2012 A3's bought had errors but they both vanished after they changed their coding.I had to gently stretch out the metal connectors on the A5 lights as they were shorter than the original ones and kept turning off once they became a bit loose .
    Ibis White 2011 A3 Sportback 2.0 TDI Black Edition S Tronic
    Extras : 18" Speedline Alloys | EBC Green Pads & Discs| Interior LED's | Gloss Black Splitter & Fog Grills | Open Sky Panoramic | Phillips Diamond Vision Fogs | OEM Silver Indicators & LED Number Plate Lights | S3 Side Skirts & Front Bumper | RS3 Grill & Back Bumper |S3 Aluminium Pedals & Mirrors | Piped Mats |RNSE| Auto Dimming Mirrors | Roadhawk Pro |Twin Chrome Oval Exhaust |
  18. #57
    Feb 2013
    Mine does the same thing..... SHIX
  19. #58
    Nov 2012
    Bournemouth
    37
    Quote Originally Posted by wow676 View Post
    hmmm. At least its not just mine. But what a weird fault!!
    I assume theres not much we can do but does anyone have any ideas?
  20. #59
    Feb 2013
    It threw an error couple of times, but now I leave my light settings to Auto to have the CH/LH function work
    It does not throw an error now even though I start the engine.
  21. #60
    poli84's Avatar
    Nov 2010
    Melbourne. Australia
    430
    Quote Originally Posted by Asarao123 View Post
    You definitely have friends with a 2010 (MY10) who have installed the OEM A5 LEDs and have been able to change their coding and get them working?
    MY10 S3 Sportback - 6Sp Manual - Sprint Blue
    REVO Stage 2+ /
    Forge Twintake / 3" Miltek Hybrid DP/​ Autotech HPFP
    Bilstein PSS10
    / H&R 10/12mm Spacers / BFI Dog Bone /EBC Yellowstuff
    BUILD THREAD
  22. #61
    Nov 2012
    Bournemouth
    37
    I dont have auto lights. Oh well, I guess I will just have to remember. Its just a pain to turn off the lights before I restart the car.
  23. #62
    Nov 2012
    Bournemouth
    37
    Quote Originally Posted by poli84 View Post
    I guess this is the other option, just to go to Audi and get the software on the CE updated.
  24. #63
    Nov 2012
    Bournemouth
    37
    A quick update in case anyone else wants these. After I retrofitted Bi-xenons, I don't get the error when re-starting the car with the lights on. I have no idea why, as no settings apart from coding for the headlights has been changed.
  1. LED numberplate lights
    By ElliottB in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd January 2012, 19:32
  2. White LED rear numberplate lights
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2011, 12:41
  3. LED Numberplate Lights staying on
    By sc00byd00byd00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th December 2010, 08:37
  4. LED numberplate light error
    By asad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2010, 10:41
  5. Attempted to fit LED numberplate lights - Not gone well
    By Minstadave in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2010, 20:50
