I'll be having mine vinyl wrapped professionally.
If I go somewhere decent for the work you'd never know they were wrapped.
And it's got to be cheaper than buying new mirrors and easier to self
reverse and restore to original.
Although they are truly things of beauty, they have to be disguised.
At least the vinyl will protect the originals from minor scuffing and stonechips.
They advertise the A3 variant you have to the wrong people
unfortunately. Sleeper FTW.
Yeah this. There must be someone out there with a black A3 that would snap your arm off for some S3 mirrors. Perhaps you could do a straight swap? I'd certainly be PM'ing you offering mine if I wanted them
yep, door cards off to get the mirrors off. Having said that I don't think you need to take the whole mirror off, just the plastic casing which you are changing. Pull the glass out and then un-clip the casing.
If you want to change the mirror caps push the glass in closet to the door and then put your finger behind the glass on the outer side and gently pull the glass off it's clips.
Then there are 2 clips that hold the mirror cap onto the base at the back of the mirror cap towards the top which you just push in with a screwdriver or similar and then slowly work your way around the base gently lifting the cap up off the base. It's not easy the first time you do it but as long as you don't use too much force the cap it base shouldn't break. If you have the facelift mirrors then you will also need to unplug the indicator wire before fully removing the cap and lifting it off the base.
