Volks AutosSky Insurance
Results 1 to 8 of 8
    pinterovski's Avatar
    Oct 2010
    661
    Add pinterovski on Facebook
    Audi S3 2008 Needle Sweep VCDS
    Hi!
    I am trying to do this thru the VCDS and it seems that i dont have the long coding
    helper to activate this! I believe this is the thing but like i said,i dont have the this options!
    [Select]
    [17 - Instruments]
    [Coding - 07]
    [Long Coding Helper]
    Click on each of the Byte numbers in step 3) and you'll see the selectable options below.
    Check the box for "Gauge Test/Needle Sweep active"
    [Do It!]
    Is there any other way to activate this?
    My car is year 2008,so i think it should have the right cluster for needle sweep!?
    I checked the whole forum and i didnt find any right anwers! If i missed some good thread
    how to activate this than post the link please.
    Cheers!
    J.
    Black roof,Tinted windows,Solar Orange Calipers,KW V3 Coilovers,
    HEKO Wind Deflectors,CAI ITG Maxogen,Non Res Supersprint Exhaust CB with custom Fi76mm DP,
    RevD with GFB DV+,Autotech HPFP,Custom SKN map Stage2,Forge ShortShifter,THS mounts,
    Twintercooler,Clutch is now on LOBA/SACHS!!!
    18 OZ Ultraleggera!
    365HP and 500NM of torque!
    Oct 2010
    661
    Anybody?
    18 OZ Ultraleggera!
    Jan 2012
    1,837
    Give people a chance to reply man!
    Especially 'cos its Sunday - we don't live on the forum 24/7 yano!
    What colour is your DIS? Iirc it's only available on white clusters.
    Oct 2010
    661
    Quote Originally Posted by A6CR View Post
    DIS colour is red. A friend of mine also has this feature on his prefacelift S3 year 2007,mine's 2008.
    18 OZ Ultraleggera!
    Jan 2012
    1,837
    Try going into Adaption instead of coding and see what the drop down menu says.
    Reload's Avatar
    Bird is the Word!
    Jul 2010
    Midlands
    367
    Re: Audi S3 2008 Needle Sweep VCDS
    Had a look into this for my 2007 S3 with no joy, don't think it can be done but will be interested to see if this isn't the case
    S3 8P2 Ice Silver, RNS-E, Bluetooth, iPod connection, Adaptive xenons, black styling pack, sunroof, privacy glass
    Mods since owned: Milltek Resonated TBE, Neuspeed P-Flo, Loba HPFP, Sachs Clutch with Loba SMF, Unicorn Motor Developments custom remap, brakes + suspension upgrades, LEDs internal and external, more interior kit
    AndyParker's Avatar
    Aug 2012
    Cardiff
    164
    Have you guys got a video of what you are trying to achieve?
    I ask because I think mine does the needle swap back and fore on ignition on - mines a 57 plate 2007 8P2 with red DIS
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    +1
    on every car I have enabled this it was done under the ‘Adaptation’
    You are looking for “Staging”
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
  1. Can Needle Sweep be activated on 2011?
    By pretarion in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th January 2011, 12:58
  2. Needle Sweep
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th July 2010, 15:14
  3. 2010 Audi S3 Sportback - alarm beep - VCDS
    By ved789 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th March 2010, 14:09
  4. Needle sweep!
    By navnayyar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2009, 14:22
  5. Needle Sweep feature on MY07 S3s...
    By Rabbit222 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2008, 20:54
