Volks AutosChris Nott
Results 1 to 10 of 10
    nevergivup99's Avatar
    Feb 2011
    27
    Has Anybody fitted heated seat elements to there front seats ????
    I am looking into retrofitting heated front seats in my 2007, 3 door A3 , I have priced up the heater controls which are about £70 for my model , and the Kufatec harness.I have checked out a few forums for advice ,but seem to draw a blank on the actual fitment of the elements,
    When I removed the seats on an earlier task ,I noticed moulded shapes in the foam underside of the seats , is this where the elements fit ,or does the fabric cover of the seat have to be removed to install the elements between the cover and the foam ???
    Is this a task that can be done at home, and do I need any special fixings or tools
    Does anybody have any photographs to share or fitting details ,or has already done this task and is in a position to instruct me .
    Nov 2012
    57
    Excellent question. Having come from a MK5 Golf with heated seats i must admit i do miss them especially on cold winter morning waiting for the car to warm up. My A3 Sportback doesn't have heated seats and that is one MOD on my list i would like to do.
    Flat Out
    Apr 2007
    Essex
    144
    Boys , you need to contact Johnny at JMB retrofits. He is on this forum. He is based in Hartlepool.
    May 2009
    43
    yes I have , from start to finish completed the install this august.
    Feb 2011
    27
    How did it go , did you fit the elements yourself or go to a vehicle seat upholsterer to have them done ?? did you make the harness, what did it cost you , in parts ,labour ,physical pain , sliced fingers and plasters ???
    May 2009
    43
    Heated seats
    Yes, I did the full install myself. Seats stripped down elements fitted.
    Feb 2011
    27
    Tell Me more , what were the problems ???
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Quote Originally Posted by gaz4410 View Post
    Top secret stuff then?
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Sep 2009
    Trotters, Peckham
    509
    you need to take off the seat skins its tedious but doable
    purchase the elements from audi; standard and sport seats have differing elements
    spray glue to the foam
    put on elements
    connect harness
    do not mess with airbag harness and make sure you do not disconnect any of the air tubes on the airbag harness
    put back covers and have fun with those pesky plastic tabs
    it takes around 6 hours
    Feb 2011
    27
    what are "the pesky plastic tabs " ? is that 6 hours for the whole job ,or per seat ? where did you get your harness from ?
  1. Has anybody fitted B8 S-line 5 spokes to their B7?
    By Donald_MacIver in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th September 2012, 17:47
  2. Retro fitting heated seat elements to aftermarket seats, best method
    By supreme in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2012, 21:53
  3. Help!! Has anybody fitted RS4 b7 seats in to a regular A4 before?!!!
    By bert-a4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th September 2011, 12:10
  4. Has anybody fitted these DRL's
    By matt_hilluk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th June 2011, 17:55
  5. Retro fitting heated seat elements (B6)?
    By fourcircle in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th November 2010, 19:27
