How to remove rounded screw, number plate light?
Ben S3 8P3
Bury//Manchester//Leeds
Well I just managed to strip one of the screws in the numberplate even after being as careful as I could :(
Id very much appreciate some advice on how to now remove said screw?
Thanks,
Ben
Do a search on this forum Ben. The problem has been well documented by the many members who have had the same situation !
Get a tap and die set and put a left-handed small thread in it, then screw in a LH screw until it catches and undoes the rounded screw.
Guess it's the same as an 'easy out' kit.
Drill it out
Alternatively try to a straight screwdriver wedged in behind the light to effectively pry it out, then try unscrewing it with some sort of screwdriver/hex head
Thanks guys. Just managed to get it out now. Only to find I have been sent two right hand number plate lights so the contacts dont line up on the left hand side.
Why can nothing ever go smoothly!
