    Sep 2012
    Grimsby, Lincolnshire
    72
    is my car already mapped?
    Is there an easy way to tell? Such as the boost level a standard 2.0T runs at?
    The car originally seemed slow, I replaced the split DV and fitted a Forge DV. Now its a lot quicker.
    I've got torque, and logged a max boost pressure of 13psi. The boost seems to come in at about 3k. Does this indicate anything?
    Aug 2012
    68
    13 psi of boost is normal for standard, you would be looking at 18-19 psi for a mapped boost
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,165
    What gear was the max boost achieved in?
    It could be the Forge DV has a stronger spring than the OEM Audi one.
    My 2009 2.0T maxes about 11.6psi but again that depends on ambient pressure, air temp and humidity.
  1. If your car isnt mapped, WELL IT SHOULD BE
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2012, 21:03
  2. It turns out my car is already mapped by REVO (2006 TDI 140)
    By Beans in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2012, 18:43
  3. Has my car been mapped?
    By feck_on_a_stick in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2012, 22:07
  4. Fitting miltech to already mapped car
    By evocos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2010, 09:04
  5. anyone looking to get there car re-mapped soonish?good deal!
    By jarvis**turbo** in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2007, 01:42
