EM TuningBadger5
Results 1 to 16 of 16
Like Tree3Likes
  • 3 Post By MTRL
Thread: Getting Flashed at with headlights Dipped!!!
    Nov 2012
    9
    Hi guys,
    First time post! - We just bought a 2006 A3 Quottro 3.2 and I'm getting flashed by drivers with the lights on dip.
    Is there an easy adjustment as I don't think my model has the tumble adjuster I read about fitted.
    I also have no access or experience with vag -com.
    Maybe they just like my new car (but I somehow doubt it).
    There is a little push button just under the dash illumination thumb wheel but I have no Idea what that's for.
    The car had no owners manual.
    Charlie in New Zealand.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    have you got xeons ?
    Nov 2012
    9
    Not sure but i'm guessing so - They are very bright and white.
    There is bugger all difference in distance when going from low to hi.
    Especially with someone in the back seats.
    bez101's Avatar
    Jul 2008
    8,480
    best to take it to the mot place and have them on the machine and adjusted
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    Silly question alert but when you have been flashed are you driving on a bumpy road ?
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Is it men or women flashing at you?
    _G_, ilim and OVRA3 like this.
    ....................I'll make a build thread one day.
    Nov 2012
    9
    I noticed when I was driving my other car (CX9 which is high seated) in front of the audi, it would flash bright in the rear vision mirror as it went over bumps and they weren't exactly big bumps. (sealed main road)
    I was hoping this would be sorted by lowering the low beam setting.
    Nov 2012
    9
    Wouldn't look if it was men!
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by MTRL View Post
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    If your car has little wheel inside next to headlamp switch to adjust the beam level (consult owners manual) then you do not xenon.
    With xenons, adjustment will need VCDS or a garage with similar to make the adjustment.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    Re: Getting Flashed at with headlights Dipped!!!
    Quote Originally Posted by MrLapou View Post
    Its another matter if its got an HID kit.
    Nov 2012
    9
    Definitely no adjustment wheel so I guess its a trip to the garage!
    Thanks everyone.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,843
    is it possible they might have broken or loose mounts\clips allowing them to flap up\down on uneven surfaces, and that's why people are flashing you?
    2009 A3 SB 2.0T DSG S line
    Jack_Of_All_Trades's Avatar
    Aug 2012
    Somerset
    27
    I got arrested for flashing
    Nov 2012
    9
    I rung the Audi specialists and they said they had never adjusted headlights with an VCDS and there should be a screw to adjust them.
    I am worried they aren't as specialist as they think!
    Feb 2011
    Falkirk
    309
    I've had this several times recently as well, but its usually by the idiots the drive with there sidelights and fog lights on a quick flash back of the full beam usually stops them flashing again.
  1. Xenon headlights dipping
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2007, 14:28
  2. HELP! - Almost There With headlight Washers...
    By imported_kbininger in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th June 2005, 15:32
  3. Problem with headlight
    By laurra in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th January 2005, 09:34
  4. Xenon lights? Get flashed at?
    By slimbloke in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2004, 00:33
