Chris NottAH Fabrications
Results 1 to 13 of 13
    Apr 2010
    Nottingham
    230
    Question Strange knock on lift-off since Evoms fitted (video)
    As per the title, i've just fitted an Evoms v-flow to my S3 today and now i'm noticing a single knock noise when I lift off the throttle and the revs drop. It seems to occur roughly as the revs drop below 1000 rpm. You should be able to hear it in this video:
    Audi S3 8P lift-off knock - YouTube
    Anybody got a clue as to what might be causing that?
    '07 Phantom Black S3
    Superchips Bluefin Stage 1
    TTRS FBMFSW
    MY11 Rear Lights
    Auto-lights/Auto-Wipers/Auto-dimming rear view mirror/CHLH retrofit
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Hmm... not a clue really. Sounds like something closing as the revs drop, maybe cam related? Afraid you'll need someone more mechanical to get their head under bonnet, unless it's something common and someone else already knows what it is.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Apr 2010
    Nottingham
    230
    Thanks. Yeah I really can't put my finger on it. Wonder if it's always been there and the new intake has just highlighted it.
    TTRS FBMFSW
    MY11 Rear Lights
    Feb 2009
    Aberdeen
    2,613
    Might just be something you'd only notice with the bonnet open so, like you say, you just hadn't heard it before.
    Hunt is over
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    Did you install the heat sheild?
    If so, that may be hitting the back of the engine bay.... Cant watch the vid as i'm at work.
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    Apr 2010
    Nottingham
    230
    No I don't have the heat shield.
    TTRS FBMFSW
    MY11 Rear Lights
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    Just has a listen and it doesn't sound like anything mine does..... Weird!
    Apr 2010
    Nottingham
    230
    Hmmm, this has got me quite worried. Tempted to take the Evoms off and put the stock filter back on to see if I can still hear it. I just can't see why the Evoms would cause anything like that unless it was physically knocking against something. I can't see it moving much but it's difficult to have much of a look under the bonnet when you need to blip the throttle as well.
    TTRS FBMFSW
    MY11 Rear Lights
    Denty's Avatar
    Dec 2007
    254
    Cool
    Quote Originally Posted by ADi Nuff Valves View Post
    ive got this on my s3 and it had me a bit worried untill i figured it out.... try pinching the Diverter Valve to Intake Return Hose
    with some mole grips or the like and then blip ur engine.... i bet the knocking sound wont be there anymore... solution - fit an forge uprated silicon pipe to prevent deformation caused by the extra airflow that ur new intake causes......
    i thank ya
    08 S3: Phtm Blk Prl, 330+bhp, Evolve Remap, Forge Twintake, Sachs Organic Clutch, Forge Short Shift, 19" 2010 TTS Parallel split 5 spoke alloys, MY11 lights, RNSE Nav, Bose, 6 cd, Arm rest, Buckets, FBMFSW, phoneprep, Adaptive Lights, Black inlays
    MK1 golf swallowtail project
    : 20v turbo BAM / AGU engine, Haldex 4x4 conversion - work in progress... its gonna be a beast -
    Apr 2010
    Nottingham
    230
    Quote Originally Posted by Denty View Post
    i thank ya
    Really? Wouldn't you see the pipe deforming if it was? Is this the correct pipe i've highlighted below?
    The noise seemed to be coming from around the cone filter, maybe below it. Anyway, i've put the stock filter back on for now to check the noise isn't still there and it didn't appear to be.
    Didn't realise Forge did a replacement pipe. Might be worth a try i guess. Got any links?
    TTRS FBMFSW
    MY11 Rear Lights
    Denty's Avatar
    Dec 2007
    254
    thats the one mate...you cant see it by eye deforming..... try fitting the new version diverter valve from audi at the same time as fitting the pipe - the noise should go :-)
    Forge Motorsport FMRLH Diverter Valve to Intake Return Hose S3 8P / S3 8P Sportback 2.0T FSi Quattro 11/06> - £49.10 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Mine makes the EXACT same sound and I've not noticed any issues relating to it.
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    Apr 2010
    Nottingham
    230
    I've got the new rev D diverter. Thanks for the link. £50 for some pipe seems a tad steep!
    Cheers Acheron. I've taken the kit off for the time being but I might have to put it back on if I know it won't cause any issues.
    TTRS FBMFSW
    MY11 Rear Lights
  1. Replies: 11
    Last Post: 9th February 2007, 18:34
  2. Rattle when lift off accelerator
    By 1.8t-oxford in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2007, 11:35
  3. Strange Knocking Sound
    By Stepho in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2005, 17:49
  4. Fluttering noise when lifting off accelarator
    By imported_alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2005, 11:51
  5. Don't lift-off in a Peugeot
    By imported_mustwin1 in forum General Chat
    Last Post: 30th September 2004, 11:36
