Monster MotorsportEM Tuning
Results 1 to 20 of 20
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    Help Removing S-Line Spoiler
    I've been looking for an S-Line spoiler and one came up on eBay which was still attached to the tailgate. I quickly snapped it up and it arrived today, although I can't get the spoiler to budge! I've removed 2 bolts located in the highlighted areas in the picture below but it's still not shifting.
    I found a thread on here saying it's just double sided tape holding it in place, if thats the case it's the strongest tape I've ever seen! Does anyone have any tips to remove it without damaging it? Or is there any other bolts I've not seen still holding it in place?
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Re: Help Removing S-Line Spoiler
    They are bonded on. Very hard to remove without distorting them.
    Try heat, levering up from one end.
    Depending What they use, but generally spoilers use a polyurethane adhesive. Like sikaflex. They hold spoilers on, in all weather, winds, speeds etc for as long as the car is used. It not an easy job sadly.
    How much did you pay if you dont mind? On my shopping list too.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    Dam that is not what I wanted to hear Was under the impression that they weren't bonded on from the factory as they had to be removed to replace the rear windscreen.
    Paid £120 for it so really hoping I can get it off so its not wasted! Is there anything available that I can try and spray underneath to eat away at the adhesive?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,935
    use fishing line
    or window screen wire
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    I just used a thin knife to slowly slowly cut through it. I would be careful with too much heat on it as it can and will warp.
    Just keep pulling up and cutting, it will come eventually.
    I took the tail gate to bits and made my money back by selling the wiper motor and locking mechanism too
    ....................I'll make a build thread one day.
    TimG's Avatar
    Feb 2004
    South Coast
    932
    You'll never get it off it one piece, give it to me and I will throw it away for you
    Fishing line.
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    Thanks for the ideas, will have another go at it tomorrow!
    Nice try tim, if I ruin it in the process your more than welcome to have it! Haha
    Jul 2011
    11
    take it to a safari park and see if a babboon can pull it off for you!
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Quote Originally Posted by Ratzer View Post
    Best answer yet
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Use a similar technique as you'd use to de-badge a car - fishing line and solvent
    If its been stuck on with sikaflex or similar try petrol as the solvent
    For Sale -
    A3 rear wiper motor and arm
    A3 air vents
    56plate A3 S-Line full speaker system including amp
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    Let us know how you get on with this as I've done the same as you an got a whole tailgate with the spoiler still attached.
    tedward's Avatar
    Aug 2012
    Lancashire
    168
    I remove spoilers like this all the time at work (work in a body shop). They are removable but forget trying solvents or petrol! They are Held on with polyurethane adhesive and it doesn't like to be removed!
    Best way is to cheese wire them off with a Windscreen removal wire ( if there is enough gap not to wreck the edge of the spoiler)
    Wiring a spoiler off is a fine art and they are easily destroyed, sometimes we end up just having to order a new spoiler if they have been fitted with crazy amounts of glue.
    Another way is slow and steady with an extendable Stanley knife ( Windscreen removal spec) and loads of glass polish as a lube and slight levering to help the blade cut the glue.
    Forget heat, it has no effect and you will melt the spoiler before the glue.
    Forget fishing wire, it will heat up and snap, also the wire needs to be serated or braided to cut through polyurethane glue.
    This is braided metal cheesewire and suitable T handles and a an OLFA retractable blade knife.
    2009 A4 B8 2.0 TDI SE + 2006 A3 1.9 TDI SPORT SPORTBACK
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    Success! After 2 hours and a bit of teamwork with my brother its off!
    First off as tedward said don't bother with fishing line, I tried it and the adhesive is far too strong and the line snaps way before the adhesive budges.
    Got hold of a very thin blunt cutlery knife and pushed it in the gap along the top edge and through the adhesive, moved it along the width of the knife and pushed it though again and repeated this along the top edge and down the sides,avoiding the bolt hole recesses. In my case getting the knife through the adhesive required a hell of alot of force, but that was due to the knife I had being round at the top as it was the only one I had that was thin enough so it was able to bend through the gap.
    This allowed the top edge to be pulled up slightly and if you shine a light in you can see the 2nd strip of adhesive. This is where my brother came in handy, he pulled up on the lower edge of the spoiler while shining a light in the gap at the top so I was able to see what bits were still stuck which I cut with the knife and your good to go!
    I would avoid using wire as I can see it being difficult without eating into the edge of the spoiler itself. Definitely not an easy job but once you get the top edge free its fairly straight forward just takes a bit of patience.
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    When I started I was wondering where the adhesive strips were, so here's a picture of the underside after it was removed for anyone else needing to do this!
    tedward's Avatar
    Aug 2012
    Lancashire
    168
    Good result then! Looks like factory spec fitment on that one so it's not been off before.
    It's a nightmare when they have been removed for whatever reason (new rear screen or painting) and then glued back on with polyurethane adhesive. It's a total pig to remove.
    Good job.
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    Any recommendations as to what I should use to stick it onto my tailgate? Not sure how easy it will be to line it up so something that doesn't stick immediately might be handy.
    tedward's Avatar
    Aug 2012
    Lancashire
    168
    Quote Originally Posted by MxGaza33 View Post
    Best bet is to dry fit it first to see how easy it is. Once you are confident stick it on with double sided tape (old stuff cleaned off)
    We use this stuff at work 3M *10mm Tape Car Truck Attachment Double Side Adhesive | eBay
    With the bolts as well to hold it it should be fine and almost factory spec.
    Hth.
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    Unfortunately my current tailgate doesn't have the bolt holes so I can't bolt it on. Was thinking of using sikaflex or tigerseal to be on the safe side, shouldn't be taking it off again anyway!
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    As said, I did the same as you and got a whole tailgate with the spoiler in place.
    From what I've read, Tigerseal and Sikaflex are both much of a muchness. I need mine spraying so I'm getting the bodyshop to stick it on as well, saves me a job!
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    I used stickafex, does the job perfect
  1. Help needed: S line spoiler removal instructions
    By MTRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2012, 19:17
  2. S Line spoiler help
    By Brendan12 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2011, 19:00
  3. s-line spoiler+ OE bumper cover ADVICE NEEDED!!
    By griffj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2006, 20:30
  4. Removing boot lining!
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th December 2005, 11:40
  5. Help REMOVING Blow off valves
    By imported_Townshend2372 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th January 2005, 19:42
