    leeds2592's Avatar
    Apr 2012
    Leeds
    995
    Can This Be Done?
    Hi All,
    Bought a whole tailgate as it was a really good price and had the S Line spoiler on that I wanted.
    Was toying with the idea of either getting the spoiler sprayed and stuck on my car or getting the whole new tailgate sprayed and fitted. Pretty much deceided on the latter as I've got a couple of dents and things in my tailgate that have been annoying me.
    Anyway, how would the new tailgate fit on with regards to the electrics? The new tailgate has the wiring all intact but its just been cut off through the wiring. Should it have a connector on the end or something?
    c_w
    1,047
    It sounds like a good idea if your boot has dents anyway and might need paint. The S-line spoiler is also pretty well stuck on and is difficult to remove without slightly warping it.
    Just the wiring that would put me off though if you can ascertain how your current boot unplugs then I suppose that can be fed back out and used in the new boot? I would guess there is a loom connector in the car/roof somewhere.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Re: Can This Be Done?
    What's in tact? If theres no multiplug, it won't be a straight swap.
    You'd have to swap the wiring from yours over. More fiddly than anything.
    As the channels they run in are small.
    Some stiff rod, and electrical tape, patience, and you'll get it done.
    If there is a multiplug, it should just plug and play, providing the pinout is the same.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    leeds2592's Avatar
    Apr 2012
    Leeds
    995
    Cheers for the replies lads.
    All the wiring is intact on the tailgate itself for the wiper motor, boot lock etc, its where the tailgate has been taken off (Up in the right hand corner). I'd of thought there'd be a connector/plug sort of thing like you've mentioned but it's just wiring that's been cut.
    I'm at work atm but I'll take a photo when I get home.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Can't say I've looked on mine. But I'd imagine there should be a plug yeah. It will have to join somewhere. Older cars used to have complete looms. But everything these days is sectional.
    If it's cut off, you have 2 options. Drag the wiring out of yours.
    Or remove your plug, and fit to whats left of the new loom.
    Make sure it's long enough, or cut extra off, then you'd have to match and solder all the wires.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
  1. Retro-fit Sat Nav RNS-E (from 'concerto') - where can this be done in South-East?
    By Simon S4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th July 2011, 01:22
  2. A5 Retrofitting options - Can this be done?
    By invisible in forum A5/S5/RS5 Forum
    Last Post: 28th July 2010, 16:48
  3. 04 changed to 09 A3 rear lights ? can this be done?
    By SneakaFreaka83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2010, 13:31
  4. Should I get this work done on my 1996 A6?
    By cble8869 in forum Classic Audi Forum
    Last Post: 12th December 2003, 16:42
