Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    Jan 2012
    106
    Electrics gone crazy, car won't start sometimes...
    Started out today with boot open warning on dash, locks trying to lock every few minutes on drive to work, then alarm started going off at work, ok perhaps dodgy boot sensor. Took boot apart, checking connections, no water etc, then went to start the car. Now won’t start, turning over, the odd splutter where you think its nearly going. No lights on dash, heating and stereo working. After disconnecting the battery for the second time it magically sprang to life. Ran it a while, restarted it, now it runs with no dash lights, turned it off and now have ABS warning on dash. Tried a few more times, sometimes dash lights work, sometimes heating lights on, now back to the beginning and not starting. Also boot warning now gone. Went out again later, lights stayed on when unlocking doors then car started, with no dash lights...
    Any suggestions? Main battery earth was good, checked all fuses in car. I going on holiday first thing tomorrow so the next chance I’ll actually get to have a look is Sunday night (in the dark again!).
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,429
    no sure if its the same as the a4
    but under the binnet of the a4 theres a ecu box
    with some fuses and relays
    on the a4 water gets in and causes problems like you have
    worth a look
    Jan 2012
    106
    Cheers, will take a look on Sunday night.
    Any other suggestions welcome.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    Replace the battery?
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Jan 2012
    106
    Got back from hols, car back to normal, half way on 50 minute drive to work DIS boot warning on again. No sign of water in fuse box, battery voltages check out OK when off and at idle. Back to the beginning then thinking its just the boot lock microswitch so I've ordered a new lock. Seems to be quite a few people saying these go with and without signs of water ingress. Hopefully thats all it is...
    Dec 2012
    6
    Hi, What was the outcome, did you find the fault? I have exactly the same problems, or have you got rid of the car and I just bought it at auction?
    Jan 2012
    106
    In the end it was the connector for the boot lock sensor which had an intermittent connection. Easy fix once you have it. You can get a new one from Audi its wasn't much £5 or so. Could be that or the boot lock sensor (£35) on yours.
    Jan 2012
    106
    Is your car going crazy like mine? I beleive it must be as the alarm drains the battery badly. I was disconnecting the battery if I left it for any period of time as a new battery is £80 or so on a diesel. You can also remove the alarm fuse but I'm not sure if this actually disables alarm and headlights from flashing.
    Dec 2012
    6
    I have only had this car 24 hrs so haven't had time to check out all the problems but yes the battery drained overnight and wont start until boosted and the boot light open warning is on, then it goes to service, have also noticed the mirrors don't always work so I guess I'm going to have a busy weekend fault finding, never again will I buy at an auction,
    Where are the sensors for the warning light, in the boot or inside the door?
    Jan 2012
    106
    The sensor is built into the boot lock. You need to remove the lower tailgate trim to gain access. I think there a couple of screws near the middle. The rest is just metal clips, just give it a good yank. Battery might be on its way out to if its been left like this for a while. Depends how much you saved at auction in the first place. I saved about 1K over private on my last car and thankfully it was problem free.
    Dec 2012
    6
    Gaaday_a3 Sport
    The car is all fixed, I found that the rear window washer was leaking directly onto the lock mechanism and the micro-switch was short circuited, this is what caused the battery to slowly drain.
    I fitted an "O"ring to the wiper shaft, that cured the leak and obtained a new lock on ebay for £22.
    What a bargain and saved myself a packet no doubt.
    I bet the leaky wiper shaft is a common fault so I would advise any one with this model to remove the wiper mechanism plate and fit a small "O" ring, I wonder if I can put a patent on this repair. LOL!
    Jan 2012
    106
    Glad you got it fixed, my wiper doesn't leak (yet), think a wiper is pretty pricey so good job!
  1. Help! Immobiliser Problem - Car Won't Start
    By coajt in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2007, 18:06
  2. Replies: 29
    Last Post: 4th July 2006, 14:48
  3. Car won't start - A6, 2001, 2.7T, tiptronic
    By cruzanS in forum General Technical / How To
    Last Post: 25th November 2004, 08:40
  4. Car won't start in morning!!
    By JayA4Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2003, 23:25
  5. Car won't start in the mornings!
    By JayA4Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2003, 08:45
