Monster MotorsportChris Nott
Results 1 to 9 of 9
    Apr 2011
    63
    Plastic or metal water pump for 2.0 tdi?
    I search the forum for a similar thread,but didnt find any answer to this.
    The oem water pump for the bkd is plastic.Many people although put the metal as they think is more strong.
    Can you pls give your opinion with the advantages and disadvatages of those two pumps?
    Mar 2011
    Cleveland
    965
    Put a metal one in mine. My mechanic reckons the plastic ones are rubbish and he's done hundreds of VAG cars...
    Jun 2010
    East Manchester In the Hills !
    672
    I agree. Metal is best. My plastic one broke up and 12 months after having my cam belt done as I didn't replace the pump at the same time.
    Ended up putting another belt and tensioner on whilst I has it all apart again.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    Quote Originally Posted by lgooch View Post
    thats why you should always replace the pump with belts.
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    How much more expensive is the metal one? Is it an option at the dealer?
    chris1988brown's Avatar
    middlesbrough
    578
    always fit the metal on , there only £40 froom euro car parts and always renew your pump when doing your timing belt saves hassle later in life.
    the metal on is the better choice over plastic as it doesnt break up
    MY S-LINE 2.0TDI HYBRID PROGRESS
    MY PROGRESS THREAD
    Double J's Avatar
    Jun 2012
    London
    49
    Plastic is plastic for a reason. To make sure it gets serviced at the same time as the belt. If you know you'll change it anyway, then you'll be fine. Metal ones can seize if they're not changed.
    *edit* I would go for a metal one. I don't think I made that clear in the above.
    Mar 2012
    Southampton
    436
    Mine is some way off yet, so don't know if I'd do the indie or dealer route, but I'd certainly ratehr have something made of metal rather than plastic in there.
    Do the dealer fit the metal one if asked?
    Jun 2010
    672
    There is nothing in the Audi service book which suggests the pump has to be changed with the belt. It is merely from experience that everyone does as a new belt which is a bit tighter usually shags the bearing in the pump after a while.
    The fact that the crappy plastic impeller breaks up is just the OEM going cheap on us.
    Even if you fit the metal impeller I would still change the pump every time the belt is done due to the bearing issue alone.
    I don't think the metal version is an OEM option but I have always gone pattern part anyway and never had an issue.
  1. Replies: 12
    Last Post: 27th April 2012, 13:02
  2. Metal or plastic impeller water pump? Which one is best?
    By Mk21147 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2011, 21:48
  3. CHEAPEST PLACE FOR A WATER PUMP ANYONE B7 2.0 T FSI QUATTRO
    By AUDI A4 SLINE QUATTRO 2.0 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th April 2010, 16:27
  4. Water Pump - plastic or metal?
    By Boro&Beth in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2009, 18:42
  5. timing belt\water pump renewal
    By hendyc04 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th August 2004, 20:39
