Chris NottVolks Autos
    Sep 2011
    43
    2008 A2 2.0 TDI PD 170 engine BMN
    As above does anyone know part numbers for SACHS full standard kit for this (as per title)
    Don't want to get my bottom spanked over price. Looking for full kit (Dual mass flywheel, clutch plate, pressure plate including CSC / bearing)
    Seen this but it looks too cheap.......some have been quoting £500
    Sachs 2.0 TDi 6 Speed 02Q Dual Mass Flywheel and Clutch Kit - Darkside Developments
    Any help appreciated. Cheers
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Quote Originally Posted by Bedders View Post
    Hi mate, why do you think that is too cheap??
    That is the genuine kit, and Darkside Developments are a well respected company. A few people here have used them for parts and fitting.
    Sure they will give you a good price for fitting too if you call them mate.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Make sure you buy it with the new release bearing, you'll regret it otherwise. Takes the price up to £385, which is still a very good price from a well respected company.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    c_w
    1,061
    VAT on top of that £462, still a reasonable price I think though.
    max69vk's Avatar
    Apr 2012
    745
    You can buy the Sach setup on Ebay including the bearing and slave cylinder for £430.
  1. tdi 170 engine shake/judder
    By mickphilcom in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th August 2012, 12:20
  2. 2008 A3 2.0 Tdi 170
    By Aaz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th August 2012, 14:13
  3. Part number for TDI 170 engine cover clips please!
    By jrsteeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th September 2011, 19:46
  4. Help ! 2007 b7 a4 tdi 170....engine will not turn over
    By vw754 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th August 2011, 19:54
  5. New A4 tdi Quattro 170 phone kit
    By gradwells in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th September 2006, 15:13
