Chris NottVolks Autos
Results 1 to 14 of 14
    Sep 2012
    Prague, CZ
    88
    Lightbulb A3 RHD > LHD Lighting
    Hi, i am taking my 2009 A3 3 Door S-Line to Europe for job relocation and need to swap the RHD lighting over to LHD lighting to allow me to register it locally.
    I have already obtained LHD Bi-Xenons so need to resolve the issue with the fog & reverse lights being the wrong way round.
    Do I just need to swap the rear light clusters with LHD units? Is there any wiring involved?
    I assume that headlights are a straight swap with no coding / wiring needed?
    Could someone give me the part numbers to MY11 (darker) 3dr rear LHD lights?
    These are MY11 3DR RHD Part numbers i think? I need LHD
    A8P3 945 095 C
    A8P3 945 096 C
    shady-ninja's Avatar
    843
    i stand to be corrected.
    the foglights are the same, so are the rear lights.
    its just the headlights that need changing as the car
    needs that to pass the controltechnique which is the German
    equivalent of an MOT.
    If you have RHD bi-xenons now, think all you need to do is swap bits over.
    otherwise, you might need more work.
    Sep 2012
    Prague, CZ
    88
    i thought the rear lights were identical (RHD vs LHD) only on the Sportback, not the 3 door version - i'm sure someone will correct me if i am wrong?
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by BenC00 View Post
    You are correct ! On the three door the offside cluster has the rear fog light (red) lens and the nearside has the reversing light (white) lens.
    Sep 2012
    Prague, CZ
    88
    Thanks for confirming - i dont suppose anyone can help me with part numbers?
    LHD 3 Door MY11 Rear lights?
    Fossie
    Rhubarb Triangle
    3,961
    8P3 945 095 (nearside)
    8P3 945 096 (offside)
    Both are about £110 each
    Sep 2012
    Prague, CZ
    88
    Thanks Mike - are they def MY11 LHD units? My local Audi dealership seem to make a habbit of messing things up so i like to be armed with part numbers
    Fossie
    Rhubarb Triangle
    3,961
    Sorry Ben no they are not ! I just noticed that you had a 2009 car and didn't realise you needed 2011 part numbers !
    I'll get back in a minute but are you absolutely certain that a) they will fit your car and b) the standard rear lights are darker on the 2011 ?
    I can only give you part numbers from ETKA which don't describe the fitting or appearance of the units !
    EDIT :- revised numbers are
    8P3 945 095 B ( left hand side )
    8P3 945 096 B ( right hand side )
    Apr 2012
    N. Wales, LL22
    1,224
    how long are you going there for ?
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Fossie
    Rhubarb Triangle
    3,961
    Ben - my previous post edited now !
    Sep 2012
    Prague, CZ
    88
    Thanks Mike... MY09 > MY11 rear lights are a straight swap, however the RHD > LHD conversion will require a little rewiring.
    I'm sure it won't be too difficult
    I'm there for 12+ months....
    Sep 2012
    Prague, CZ
    88
    Update:
    I have ordered the following parts after a hard battle with the parts guy at Audi which insisted that they will not fit:
    8P3 945 095B
    8P3 945 096B
    Could anyone help me with wiring diagrams etc to help with the wiring that will be required to switch the Fog and Reverse lights round?
    Sep 2012
    Prague, CZ
    88
    I've managed to find some information on rear cluster wiring, does anyone else have more detailed information?
    Here: Zweites Rückfahrlicht beim A3 (8P) » FAudiQ.de
    Do you think the Haynes manual would cover it? I need to buy one....
    Sep 2012
    Prague, CZ
    88
    BUMP
  1. Rear Light Cluster change from RHD to LHD - Fog Light Wiring or fix ?
    By johnnyfinlandia in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd November 2012, 11:48
  2. Ordered LHD lights from Dectane.....
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th April 2012, 22:10
  3. RHD And LHD Cars.
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2010, 15:05
  4. LHD / RHD front lights .. is there a lever like the 8l's had?
    By CydonianCrusader in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th February 2008, 21:32
  5. Facelift headlight LHD RHD adjustment
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2006, 13:30
