Monster MotorsportEM Tuning
Results 1 to 7 of 7
    Oct 2012
    7
    Gearbox whirring
    hi i've just bought and audi a3 1.6 fsi, absolutely love the car but when i picked up the car noticed a high pitched whirring noise through low speeds but thought nothing of it thought it was just the natural running of the car but after looking through some history it looks like the previous owner has reported this to audi and they've diagnoised as coming from the gearbox but to no rectification. i persume thats when the owner got rid of the vehicle because it'll be out of warranty. the car seems to run fine doesn't miss a gear and is dead smooth in every gear, no clunking or stiff changes, just the noise under low speeds.
    Does anyone have any ideas? is it a case of jus low gearbox fluid?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    My car is totally different to yours,but the box always whined a bit,and slowly got worse to the point where we stripped it down.....the selector forks are prone to wear,as are the synchros,and it may be that....how many miles?
    Oct 2012
    7
    car has done 56,000 miles
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    Quote Originally Posted by mylesa3fsi View Post
    Could be what I've described,but without taking it to bits it's impossible to say.
    Is there any warranty from buying it?
    Oct 2012
    7
    yeah there's a 3 month warranty with the garage i bought it, but just thought if it was something small saved me messing around. i work for mercedes and the lads said first thing to try is change the oil and if theres no luck with that then it is to take the box off.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    One method is to drain the oil and check for bits of bearing and other debris.
    Oct 2012
    7
    yeah might do that at the weekend, i'm not even sure whether it is the gearbox now, just been out in it and when you dip the clutch it goes away but also goes away when you take your foot of the accelerator.
  1. changing the gearbox oil
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2003, 06:14
  2. Sequential Gearbox Anyone?
    By AL_B in forum General Technical / How To
    Last Post: 21st February 2003, 12:58
  3. Gearbox Repaired!
    By Joshie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2003, 08:59
  4. DSG auto gearbox... confirmed?
    By jamesa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2003, 14:21
  5. Whirring noise
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2003, 12:32
