EM TuningChris Nott
Like Tree1Likes
  • 1 Post By MartayMcFly
Thread: Strange uneven tyre wear...
    Feb 2011
    534
    I fitted some Falken FK452's at the front for the MOT, since then I have done about 15k miles and I now need another pair for the front again!!
    The passenger side wear is all on the inner edge, but the driver's side wear is on both sides of the tyre!?
    I had 4 wheel laser alignment done when these tyres were fitted last.
    Any ideas, why this kind of wear has happened and why so quickly too? As I could really do without replacing the tyres every year
    WANTED: S3 Side Skirts (3DR)
    A3 S Line DSG TDi 140 (56) | Lava Grey | Groove & Drilled Discs | Green Stuff Pads | Eibach Sportline Springs | Eibach Spacers | Full heated leather | RNS-E 2010 MK2 | Rear Parking Sensors | Interior Light Pack | Heated Mirrors
    Feb 2009
    Aberdeen
    2,490
    Inner edge could still be an alignment issue, but camber rather than toe. And outsides sounds like under-inflation (the wheel rim pushes down on the tyres more).
    BigWillyStyle likes this.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    BigWillyStyle's Avatar
    Aug 2012
    566
    The drivers tyre will be due to under inflation and for you passenger tyre the wear will be due to excessive camber in the front suspension which can be sorted by checking wheel alignment. Maybe originally it was done incorrectly or the wheel has been knocked due to hitting a curb or pot hole....hope this helps...
    EDIT: As above, was beaten to it!
    Feb 2011
    534
    Cheers dudes... will pay more attention to the tyre pressures in future
    Feb 2009
    Aberdeen
    2,490
    Quote Originally Posted by Agent_Trig View Post
    It's an easy one to overlook - over-inflation will cause the centre of the tyre to wear more too.
    Hunt is over
    Phatboyruss1's Avatar
    Apr 2010
    Button Moon
    65
    Follow Phatboyruss1 On Twitter Visit Phatboyruss1's Instagram Channel
    I'm getting bad camber wear on the inside of my front tyres (i'm running 215/35/19's and I'm quite low)
    I have been told by my local laser allignment place that the camber can't be adjusted on the 8P's. Is that correct?
    If so, would fitting adjustable ball joints solve/help my problems?
  1. UNEVEN TYRE WEAR... FRONTS ONLY...ANY SUGGESTIONS??
    By craigcull in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th July 2012, 10:37
  2. Seriously uneven tyre wear
    By V6Pete in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2009, 21:49
  3. uneven tyre wear help!
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2008, 07:39
  4. Uneven Tyre Wear
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2007, 21:43
  5. Uneven Tyre Wear
    By imported_MancheS3er in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2004, 16:08
