Volks AutosChris Nott
    flotron's Avatar
    Oct 2012
    Argentina
    Question A3 without door warning lights pack, the cables are in there?
    I have an A3 2010 without the "doors lights pack". I want to know if maybe the light's cables are in there, because i saw that the door have the red lenses and i thought that maybe i only need to add the bulbs and enable the function with VAG COM
    What do you think?
    Jan 2012
    1,633
    Search?
    My DIY guide for Retro fitting Puddle Lights
    Robin sells the looms
    Jul 2004
    54
    as above, you will need to add the loom, light units (2 per door - 1 x white and 1 x red), and key into the correct pin at the door module 32 pin plug (Pin 18 IIRC Live and 19 is earth).
    flotron's Avatar
    Oct 2012
    Argentina
    i saw that post but he dont even have the lenses, my car have it. And maybe wires too
    Jan 2012
    1,633
    They are just reflectors fitted there's nothing behind them.
    flotron's Avatar
    Oct 2012
    Argentina
    Quote Originally Posted by A6CR View Post
    Dissapointed
    I don't want to dismantle all the door for a couple of lights.
    Thank you
  1. Audi A4 B8 Door Warning Light and Puddle Light retro fit
    By pns2007 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 1 Week Ago, 13:53
  2. Door & Trunk open warning lights on the dashboard
    By TedMosby in forum VCDS (formerly VAG-COM) forum
    Last Post: 6th September 2011, 17:00
  3. Help with door warning light mod
    By justandy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2008, 13:28
  4. boot/door warning light keeps coming on for no reason
    By deanosavanna in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2007, 19:44
  5. Warning lights - the ABS and the parking brake light
    By vij31 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th March 2006, 16:10
Tags for this Thread
