AH FabricationsBadger5
Results 1 to 24 of 24
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,974
    Look what happened when the jack slipped !
    What can i repair this with?...sealant? chemical metal? the jack sliped and dug into the sill and made a cut,i dont want water getting in ,also cars going to a bodyshop in 2 weeks time bumper to be painted......any ideas what i should do here,there is a slight dent aswell.
    [IMG]http://i851.photobucket.com/albums/ab80/vw754/DSC_0414.jpg[/IMG
    Full leather/19"wheels/cruise/
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    the body shop will be able to sort this no problem. if your worried about water ingress before it going in, i'd gunk it with grease/underseal or if needs be a blob of silicone.
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    i wanted see if i can fix it myself.......bodyshop prob want 50 quid for that bit alone! i heard they can braize it or something?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    duct tape
    C6 DRN's Avatar
    living the dream
    Oct 2012
    Ellon
    221
    Follow C6 DRN On Twitter Add C6 DRN on Facebook Visit C6 DRN's Youtube Channel Visit C6 DRN's Instagram Channel
    Could grab some p38 and just get a touch up aerosol yourself? might work im not the best with bodyshop stuff!
    Audi S3 | DSG | Black Edition | Quattro | Heko Wind Deflectors | Heated Leather Seats | Bose | RNSE | Cruise Control | Sunroof | Electric Mirrors | Armrest | 6k Miles
    WAAAAAAP TSSSSS
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    For time being put some electrical tape over it till you can take to body shop for their suggestions.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Quote Originally Posted by vw754 View Post
    You'd be lucky if you got that fixed for £50 - you are looking at about £150 for a body shop to sort that out inc vat!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    tbh given its the sill, it kinda needs welding as filling alone it isnt exactly the best thing for future MOTS
    Oct 2012
    Fife
    59
    I wouldn't advise putting grease/silicone on there as if you do want it painted you will have to panel wipe (de-silcone for ages!) To do it right it needs welded, filled then painted. luckily, its on the sill and tbh you could repair yourself.
    If you get some one to weld the "gash" up. Some p38 (filler) as someone has already said. Then some rattle can stone chip (the rough effect) and rattle can base coat and lacquer! sorted
    I can give you some advice if you would like.
    Oct 2012
    Fife
    59
    Quote Originally Posted by Byzan Pics View Post
    Beat me to it!
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    if grease/silicone is used as a temporary measure, id see this as no problem. The at paint work around hole and the hole will be ground back prior to welding. this would remove all contaminants. so dont really see any issue's but I may be wrong
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,406
    Follow Brodster On Twitter Add Brodster on Facebook
    Have you ever seen the tap test that MOT testers do on the sills of cars. Their toffee hammer would pick up a filler repair in no time at all unless you know the tester ;-)
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Aug 2010
    1,540
    its a scratch and a little dint isnt it? last thing you want is welding on a sill on a 5 year old car. welding encorages rust, it heats up the surrounding metal disturbing the original paint and will melt the wax off the panel on the inside. touch it up with primer and colour and leave it.
    Aug 2010
    1,540
    Quote Originally Posted by Brodster View Post
    naaaa. im a tester, you wouldnt pick up on a tiny skim of filler on such a localised area on a sill ever with it.
    infact i havent picked up the corrosion hammer since the last ford ka i tested about 2 months ago!
    Oct 2012
    Fife
    59
    Quote Originally Posted by rOb_A View Post
    Yeah suppose. I didn't mean to shoot your idea down
    It should be welded for sure and a skim of filler. if its a big dent get the body shop to pull it out and weld it and just paint it yourself?
    Mask it with a soft edge. (doubled of masking tape) with it being the rough texture you shouldn't see it.
    Oct 2012
    Fife
    59
    Quote Originally Posted by murran View Post
    Why would you check a ford KA? They never rust haha..... I would use a big hammer for testing that. 14lb and smash it up!
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,406
    Thats good to know as I've seen several of them go hammer and tongs on a filler repaired sill. I wasnt too chuffed when I had to get it welded properly.
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    THEY PROBABLY WOULD.....especially if im spending 400 with them anyway
    Quote Originally Posted by RobinA3 View Post
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    i wouldnt like get it welded......its so so tiny,just a slit on a piece of paper......What about dabbing in some chemical metal then touching in with touch up paint,it'll be filled,solid and end of.
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    Thats great.....alot of m.o.t testers see the cars mint on the body,dont bother with the hammer
    Oct 2012
    Fife
    59
    The correct way IMO is to weld it. Just fill and paint if you wish. You will need to stone chip it to get the rough texture back though.
    Aug 2010
    1,540
    the picture is a little rubbish, has it actually cut a slit into the sill (as in a hole) or not?
    Apr 2004
    12,523
    It seems like you are going to bodge it up anyway, so I guess it's up to you, for £50 is it really worth bodging????
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    944
    Time for some side skirts :P it will go right over that.
  1. Whats happened to the wheels on this tt ?
    By t-sport in forum TT/TT-S/TT-RS Forum
    Last Post: 21st November 2006, 20:43
  2. What happens when that...
    By neversaydie in forum General Chat
    Last Post: 26th September 2006, 09:12
  3. What happened to the AMD threads?
    By imported_monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2006, 07:58
  4. what happened to the 2.0Tdi Revo'd graphs
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th December 2005, 23:42
  5. What happened to the Armrest GB ?
    By MattS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2005, 09:26
