Monster MotorsportChris Nott
Results 1 to 13 of 13
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Radiator staying on when all turned off?
    Hi guys
    Any reason why every so often my A3 2.0 TDI 170's front radiator is staying on for about 5 minutes after i've turned the engine off etc? It's done it twice now and happened tonight after returning home on my usual 13 mile journey home from work, I wasn't exaclty thrashing it either.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Jan 2012
    1,601
    DPF regen interrupted I'd say.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,612
    you mean the fan.....?
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    The fan on the radiator then...
    26,721
    Do you run aircon all the time or just occasionally & was aircon on at these times.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Have a read of this thread:
    possible radiator fan problem
    It's a common problem on A3s.
    Please have a look at the FAQs thread too, that's where this link came from.
    8P2 S3
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,571
    Fairly common fault.
    Open the bonnet with the engine running an AC off and watch the fans. Only the large radiator fan on the right should be moving.
    Now turn on the AC, wait a few minutes and keep watching the fans. If the smaller fan still doesnt move and the large radiator speeds up and sounds like an aeroplane taking off.. The fault is with the smaller fan.. £150 for fan + labour.
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    883
    Or the DPF re-gen has been interrupted as A6CR says. I get this on the A4 from time to time, usually with a slight smell of burning (I'm assuming from the increased tempteratures needed for re-gen)...
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Always stays on mate.
    Quote Originally Posted by jb0o View Post
    I'll try this out.
    This is helpful too -
    Air Con/Climate control FAQs
    It's possible that's it's normal behaviour as my air con is always on.
    I'll do some tests and report back.
    Thanks chaps.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    I should also mention that the car was checked for error codes via VCDS only last Sunday and no errors were present....
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,850
    Sounds like the common fan problem as this shows no errors. Get it sorted though as you'll come back to a flat battery!
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Quote Originally Posted by audicruiser View Post
    its only done it twice in about a month though, both times it's gone out in about 5 minutes. Surely that won't flatten the battery?
    Oct 2012
    hi
    try the temp 3 pin switch situated screwed in the radiator, this keeps the fans working after the engine in switched off and works on a temp in the radiator, cheap to change, also is the engine temp normal if is reading high the fan will run on after switching off
  1. Turn off warning message when starting automatic
    By SteveSmythe in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th May 2011, 09:36
  2. Replies: 5
    Last Post: 18th February 2011, 19:54
  3. A4 (B6) fan staying on when engine is off.
    By paulfromwire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th August 2010, 08:28
  4. S3 xenon headlight turning off when hot?
    By guinness in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2010, 16:46
  5. Why does the car turns off when...
    By abdus in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2008, 17:32
