    LSH
    Oct 2009
    24
    2 Vagcom Fault Codes....Can anyone diagnose / help?
    Hi all,
    A household car has 2 fault codes of which have been cleared numerous times and keep returning.
    The first fault is clearly something to do with the engine fans, but before spending a decent amount on a new set is there antything else that could be the issue (as opposed to failed units)?
    With regards to the second fault, I am completely stumpped as the car starts, drives and runs fine (without any obvious issues).
    Does anyone have any tips of what these faults are, how to test them or even how I can potentially resolve them?
    Thanks,
    Luke
    1 Fault Found:
    18354 - Control Module 1 for Coolant Fan
    P1946 - 000 - Defective
    Freeze Frame:
    RPM: 0 /min
    Torque: 88.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.93 V
    Bin. Bits: 00101100
    Temperature: 18.9°C
    Duty Cycle: 9.6 %
    1 Fault Found:
    01177 - Engine Control Unit
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 158
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    01177 - Engine Control Unit: Faulty
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    Possible Causes
    • Wiring and/or Connector(s) from/to Engine Control Module (ECM) faulty
    • Engine Control Module (ECM) incompatible
    • Engine Control Module (ECM) faulty
    • Engine Control Module (ECM) modified
      • Immobilizer removed
      • Chiptuning (Chip replaced)
    Possible Solutions
    • Check Wiring and/or Connector(s) from/to Engine Control Module (ECM)
    • Check/Replace Engine Control Module (ECM)
    • Check Engine Control Module (ECM) for Modifications
      • Old Style Chip Tuning where actual Chips are replaced may have resulted in bad Soldering or otherwise broken the ECM.
    01177 - Engine Control Unit: Unauthorized
    Possible Symptoms
    • Engine Start not permitted
    Possible Causes
    • Immobilizer not adapted
    Possible Solutions
    • Check/Adapt Immobilizer
    01177 - Engine Control Unit: Not Currently Testable
    Special Notes
    • When Found in Instrument Cluster (J285), check Engine Control Module (ECM/#01) for Fault Codes. This Code may be stored when the Cluster is unable to properly determine the Status of the ECM due to Communication Issues or because the ECM is occupied by other Tasks.
    Retrieved from "01177 - Ross-Tech Wiki"
    Category:
    Categories
    Meta
    LSH
    Oct 2009
    24
    Cheers for the reply Bez [y]
    I did also have a look on the rosstech wiki for the fault codes previously. The odd thing is that the car has no starting issues, no running issues, has never been mapped (as far as im aware) and there is no MIL light either.
    The one part that got my attention was:
    Has anyone else experienced this, or resolved it?
    Luke
    LSH
    Oct 2009
    24
    Bump
    27,029
    Post the full log please.
  1. Fault codes can anybody help ?
    By macpdm in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2011, 19:53
  2. Vagcom fault codes
    By mikerd4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2007, 12:52
  3. Can Anyone Please Help ?
    By ANNANBHOY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2007, 14:34
  4. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
