Volks AutosBadger5
Results 1 to 7 of 7
    Oct 2012
    PLEASE HELP!! Fault code 01332 passenger door communication error
    Hi everyone
    I have a 2005 2.0 TDI which has had the passenger side door skin replaced(used from ebay) as someone kicked the old one. The replacement door was bare so all parts were transferred from the old door. Soon after we noticed the door is not locking and also the alarm, interior light and onboard computer are not acknowledging when the door is open.
    My friend has a SnapOn scanner and pulled a 01332 fault code from car which says a passenger door communcation error.
    The car went to a reputable mechanic and he said it was sure to be the latch/catch so had it replaced and as we expected it did not fix it.
    The car is now with an auto electrician who has had the car for 6 days and still cant find the fault.
    One other thing the car was not used for several months prior and the door was fitted with a flat battery(not sure if this makes any difference).
    Any advise would be hugely appreciated.
    Laura
    Oct 2012
    Sorry should of also mentioned the window works fine.
    Oct 2012
    Bump... Anyone of you kind people have any suggestions?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Hi mate, try and get it scanned with VCDS by someone local to you.
    If all was working fine before you transferred over, then it is possible, things have not been connected up correctly or you have lose or broken wires. Also check your fuses.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Oct 2012
    Thanks for the reply.
    I'm quite sure it was working before and the fuses have been checked. I kind of think it may be loose broken wires too but would of thought the electrician would of picked up up that. I spoke to him on Friday and he said it's baffling him Will see what he say's tomorrow and then may look for someone with VCDS.
    Thanks again
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    What area of the country are you mate? I am in North London if that is any good to you? Otherwise, check out this VCDS user list for someone close to you http://www.audi-sport.net/vb/vcds-fo...%2A%2A%2A.html
    27,099
    Given it has comms errors, then its more than likely wiring if worked before, door modules dont go faulty often, as advised whereabouts are you located as maybe abl to resolve for you if the auto leccy cant work it out.
  1. arghhh please help, fault codes keep increasing
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2010, 21:37
  2. Please help with codes..airbag.
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th July 2008, 02:01
  3. need help fault code
    By audi-90qua in forum Classic Audi Forum
    Last Post: 28th October 2007, 12:22
  4. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  5. Please help me with an A3 door problem.
    By JeremyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2004, 06:17
