Volks AutosEM Tuning
    Apr 2004
    1,139
    Folding mirror problems
    Hi, can anyone give me any help on this.
    My drivers side mirror doesn't always fold out with the passenger one. This has been going on for a while and started as just happening once in a while - its getting more frequent now though. If i wind the window down and tap the mirror with my hand then operate the switch again it usually folds out - until next time.
    My mum has a seat altea (based on same chassis/mechanicals/electrics) and her mirrors sometimes do the same - but with the passenger side one.
    Would you say this constitutes a fault or is it just a 'characteristic' of the folding system on these? Or does someone in the know, know how to solve this problem?
    I also have the issue of the mirrors folding themselves out on their own upon engine start in cold weather - which i believe is normal and common amongst these.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Seems like intermittent fault. Perhaps dirt/moisture in connector.
    Remove the mirror glass and check connections inside.
    Search on this site for a thread on how to remove the glass.
    Apr 2004
    1,139
    Take it this is a common problem then? Is that where all the electrical connectors to do with folding action live - behind the glass?
    Suppose if it is easy enough, could be worth whipping it off and cleaning all the connectors.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    seems logical place to start since tapping the mirror housing gets it to work
    27,096
    Does this aways happen when car not runnng?
    Its a known bug & if you fold when cars running, it seems to work ok mostly, I put it down to power issues tbh, if under warranty could try to get door module swapped out.
    Sim_88's Avatar
    Jun 2012
    London
    55
    I have this problem with my mirrors too, I sometimes have to flick the switch twice. I think its a power issue as when I have the interior lights on the lights on the mirror switches take a bit longer to come on so its my theory that the switches are slightly delayed in terms of becoming active. If I wait 20 seconds after switching on the ignition the mirrors always work, nothing to worry about..
    2.0 TDi S-Line | BOSE | iPod | Full Leather | Electric Mirrors | Armrest | Rear Tints | Diamond Vision | MY11's
  1. Folding Mirror Problem
    By hambo0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2011, 18:49
  2. Electric folding mirror problem
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th May 2011, 19:22
  3. Folding Mirror Problems
    By stevieboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th November 2005, 20:13
  4. HELP!! Heated rear window and wing mirror problem
    By tboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th November 2004, 14:14
  5. Heated Mirror Problem??
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2003, 10:24
