Sky InsuranceAH Fabrications
    Yaseen1991's Avatar
    Aug 2011
    102
    BKD OIL PICK UP PIPE???
    Hello everyone, still having problems with my car. Put in a new hybrid turbo on my BKD 2.0 tdi a3, within 6hours my car drank ALL its oil
    was thinking inlet seals or headgasket, but got the turbo off today and the 4 ports on the engine side are all bone dry, my mechanic tells me its a faulty turbo unit whereas the turbo supplier is adamant its a blocked oil pick up pipe and i should get the sump off to have a look :s
    seriously puzzled and wondering if any1 had same prob or similiar
    hybrid turbo was only fitted a week vefore my car lost all its oil, the turbo guy saus putting a hybrid on would only have made the problem more apparent, is he chatting bubbles or could he be right?
    thanks
    Lewis583's Avatar
    Mar 2010
    870
    Was the turbo oil feed pipe replaced/inspected/flush through when the turbo was replaced?, I always recommend the feed pipe is replaced when a turbo is.
    Also if the turbo has gone and the oil isn't in the exhaust it will more than likely be in the intercooler, this must be cleaned out prior to restarting otherwise you run the risk of the engine running on the oil = Mucho RPMs.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Yaseen1991 View Post
    thanks
    That's why recon. turbo suppliers always require a new oil feed pipe fitted with the turbo.
    Turbo warranty is void if you don't have it.
    Your mechanic should have known that.
    Yaseen1991's Avatar
    Aug 2011
    102
    My mechanic did know that hence why he changed the oil feed pipe when the new turbo was fittet...
  1. Oil Pick up pipe Sludge
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd February 2014, 15:18
  2. Oil pick up pipe done!
    By scotty_24 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2012, 00:05
  3. oil pick up pipe
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2011, 21:29
  4. Replace pick up pipe naturally, also clean oil feed / return pipe?
    By mikem1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2011, 18:05
  5. Oil pick up pipe question.....
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th September 2010, 16:53
