EM TuningChris Nott
Results 1 to 7 of 7
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    HELP!! I'm thinking the worst...
    Not sure if you can see that (taken on iphone) but when changing my drl (S3 56plate) i seem to have broken the reflector part but also one of the 3parts that holds the bulb into the unit.
    My worry is that i'm going to have to replace the whole headlight unit?
    Has anyone else done this or is it just me being a muppet?
    Any help would be much appreciated...
    Dom
    warren_S3's Avatar
    Oct 2007
    6,201
    Doesn't look good from what I can see, will allow ingress of dirt and moisture. Likely you will be changing something, but whether it will be the whole unit????
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    It's not the rear part that, i can still close the headlight unit so no dirt can enter it's just that the drl bulb wont go back into the slot where you twist it into the holder. It wobbles and sits funny, like its not in.
    warren_S3's Avatar
    Oct 2007
    6,201
    Is the cracked part floating about in the headlight unit?
    If the bulb can't be located securely I'd say its inevitable you will have to replace the headlight unit as I'm sure it's one piece.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    I couldn't find it. It's like it's vanished.
    Oh great.
    dansansome's Avatar
    Jun 2008
    bournemouth
    165
    That sounds bad, does it look like you can get the reflector part out? If audi will only sell you a new unit, you could try and get one from a scrappy that has s good reflector but broken lens? Should be cheaper than a brand new or second hand one.
    I think I saw a mod to blacken the non reflector parts in a4 b6 headlights, iirc it involved some warming or baking to soften the glue to get them apart?
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Not sure, i'd have to take the headlight unit out to find out.
  1. Dont think the quattro system will help today
    By bluequattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th November 2010, 17:29
  2. Well fellas I think the A3 might be going....
    By Mark_N in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th September 2005, 07:25
  3. Finially decided for a change, how do you think the S3 will...
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2005, 14:05
  4. Oh Dear - maybe the worst loaner you can get...
    By audi_girl in forum Other Brands & Models
    Last Post: 20th April 2004, 17:46
  5. Do you think the A3 needs a 6th gear?
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2003, 15:19
