AH FabricationsVolks Autos
Results 1 to 8 of 8
    Ben S3 8P3's Avatar
    Jul 2012
    Bury//Manchester//Leeds
    313
    S3 Brake pads - are they worn?
    How can I tell if my brake pads are worn down. (8P3)
    Im not overly impressed with the braking performance, and I think it must be down to worn pads.
    How often do people usually change theirs?
    And do you all have a preference to an upgrade of pad that is also quite long life.
    Thanks for your help,
    Ben
    Dec 2008
    278
    A pretty cave-man style basic test would be to have a look at the gap between caliper and disk. If that gap is too small to get your little finger in then the pads are reasonably worn!
    Ben S3 8P3's Avatar
    Jul 2012
    313
    I didnt mention. Its done 19,000 miles and I dont think they have been changed
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,157
    Should last more like +30k miles.
    Ben S3 8P3's Avatar
    Jul 2012
    313
    Quote Originally Posted by MrLapou View Post
    Oh really? That seems like a long time, because I presume the car will have been driven hard at some point.
    They do seem effective with some pressure but they lack the initial bite that I would have expected
    Double J's Avatar
    Jun 2012
    London
    49
    Maybe needs bleeding?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,157
    all makes and model of parts are not equal. If in doubt . change them mate.
    warren_S3's Avatar
    Oct 2007
    6,067
    Mix of opinions on performance pads. Some like Ferodo DS2500, others like EBC yellows, but some just go for a full disc pad upgrade!
  1. Worn Brake Pads
    By hardeep1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2007, 22:09
  2. worn brake pad warning on, but pads /wires are ok
    By DodgeT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th October 2006, 20:01
  3. A4 Brake pads worn symbol
    By vanbasten in forum General Technical / How To
    Last Post: 21st July 2006, 11:50
  4. Brake Pads Worn - How long?
    By imported_Strider81 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2005, 17:48
  5. Brake Pads - Which are your favorite?
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2004, 09:49
