Volks AutosAH Fabrications
Results 1 to 8 of 8
    Jun 2012
    12
    Coolant temp sensor help
    Engine managment light came on a few days ago i ran vcds and it came up with the error " coolant temp sensor radiator outlet g83 or 63" i changed the coolant temp sensor at the back of the engine 2 months back and need help finding this one now and any part numbers if anyone knows,thanks
    Lewis583's Avatar
    Mar 2010
    870
    Engine code? Year?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jun 2012
    12
    its 2004 2.0 tdi 140bhp. i didnt write the code down ill connect it back up tomorrow and find it. it just said about the sensor on the radiator outlet saying limits too low
    chris1988brown's Avatar
    middlesbrough
    578
    there should be a plug inline on the outlet pipe of the radiator hose held in with a clip un plug, remove clip pull sensor out , repace and repeat
    MY S-LINE 2.0TDI HYBRID PROGRESS
    MY PROGRESS THREAD
    Jun 2012
    12
    wheres the outlet pipe is it at the top left as u look over it
    middlesbrough
    578
    if i remember correctly its on the n/s of the car
    MY PROGRESS THREAD
    Jun 2012
    12
    sound. i found the other no problem but cudnt figure out which pipe was which on this one. could do with draining the coolant too n putting fresh in
    Aug 2010
    1,540
    is this a bkd engine? i think the g83 is in the plastic housing that holds the thermostat in or in the lower hose to the radiator?
  1. Continuous Engine Coolant Temp. Sensor Problem - PLEASE HELP!
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2009, 15:25
  2. Help! Where's the Coolant Temp sensor?
    By FactionOne in forum General Chat
    Last Post: 12th April 2006, 09:44
  3. URGENT - COOLANT TEMP SENSOR
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 22:13
  4. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  5. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
