Monster MotorsportBadger5
    Chris-gsxr's Avatar
    Oct 2012
    57
    Water in rear light.
    I have just noticed water in the rear lhs light on my 09 a3 sports back. Any idea what the problem is and or how to stop it from happening again?
    Jan 2012
    SW London
    794
    Common problem with the water seals apparently. Take ur lights off and check the rubber seals between the cluster and the bulb holder.
    Make sure its all straight and the groove in the center of the rubber is in the middle throughout.
    Also inspect the clusters, if there are any cracks in them there might be water leaking through from there.
    Buy some electrical contact cleaner and clean everything out, u need to make sure theres no water left on the inside that could damage any of the components on the bulb holder.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Chris-gsxr's Avatar
    Oct 2012
    57
    I will do that over the weekend, Thanks for your help
    Chris-gsxr's Avatar
    Oct 2012
    57
    Turned out it was not a water seal but somehow the light unit itself had starter to separate. Took it out. Pointed a hair dyer through one of the bulb holes to dry it out, gave it a good clean with wet wipes,and ran a bead of clear silicone around the joint where it had came apart. It's now water tight again with no condensation inside the unit.
  1. rear light bulbs
    By ultrasporta4vk05 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th May 2004, 04:05
  2. changing headlights and rear lights to facelift
    By youngdriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2004, 23:10
  3. Rear light cluster's
    By skippy in forum Tuning
    Last Post: 22nd January 2004, 18:44
  4. A6 Rear Lights
    By skidooman in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd November 2003, 12:29
  5. Smoked Rear Light Lenses for 2003 A6 Saloon
    By cliffcartwright in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th October 2003, 14:28
