Volks AutosSky Insurance
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    842
    Issues after Rev D DV
    Hi All,
    After replacing my old Rev C DV with a Rev D last weekend (which took all day because some idiot had rounded the 3 torx heads) I am still getting "leaky air noises" from the footwell. It sounds like normal DV noise but lasts about 2 seconds, is quite high pitch ... also air noise on acceleration and engine breaking.
    Turbo response is improved from the new DV, torque shows im boosting 0.65 bar peak and 0.55 bar sustained, MPG is a bit low (17-20 town driving in Hilly Sheffield, 28 max motorway being careful).
    Any ideas what I can check? Im really new to DIY car stuff so learning as I go.
    Thanks in advance!
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,850
    Check all pipes from the turbo to the intercooler and the especially the pipes either side of the intercooler. These do give leaks sometimes and can even pop off in some circumstances.
    I am assuming you replaced the rounded torx bolts when fitting your new Rev D? If you didn't then how do you know they are tight and the Diverter Valve is sealed properly, also did you use nut lock on the bolts?
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    wuta3's Avatar
    Jul 2012
    842
    Thanks for the reply,
    The bolts were replaced, so should be good and tight. I'll check the piping tomorrow, it's a tight squeeze back there!
  1. Compression issue after injector recall
    By nick1 in forum General Automotive Chat
    Last Post: 4th September 2012, 01:14
  2. 2.0T hesitation issues after service.
    By viceroy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th June 2012, 14:22
  3. Dash Illumination Issue after HU Install
    By _GRP_ in forum In-Car Entertainment
    Last Post: 22nd March 2011, 22:45
  4. climate control issues after rns-e install
    By B6 ESSEX in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2010, 19:53
  5. Dealership issue after 5 days
    By simon-s3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th March 2008, 18:37
