Results 1 to 13 of 13
    AndyParker's Avatar
    Aug 2012
    Cardiff
    164
    Noob Xenon question
    Hi guys - apologies for the noob question but was there a point when Xenons became standard equipment on the 8p S3 or have they always been optional?
    Is there an easy way to tell if a car has them? The headlight washer perhaps?
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Follow Helifella On Twitter
    My Black Edition has Xenons as standard with the LED "frowning" DRL's. I think you are correct about the washer units and also when unlit you can see the way the lamp is made wether it has the LED section along the top edge or the light bulbs DRL's at the bottom. also with Audi xenons they will have have auto levelling so next to the light switch inside there shouldn't be a height adjuster switch.
    Regards
    HeliFella
    I.A.M. Member http://www.iam.org.uk/about-us/
    '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,
    Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates,
    gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    AndyParker's Avatar
    Aug 2012
    Cardiff
    164
    Thanks Helifella
    i'm conscious that the LED DRL's only came into play on '58 plate and onwards (?), what's the score with the none LED DRL Xenons if there is such a thing?
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    They might be out there but i'm less than a year into the brand so not really qualified to say :-)
    Regards
    HeliFella
    AndyParker's Avatar
    Aug 2012
    Cardiff
    164
    No problems you're further into it than I am so appreciate your help!
    AndyParker's Avatar
    Aug 2012
    Cardiff
    164
    Maybe a photo will help - are these Xenons?
    Aug 2012
    Yes they are xenons with non led drl lights
    Mar 2007
    Cambs
    471
    On the whole Xenons are like rocking horse crap on the A3's, hence why its taken me a stupid amount of time to find the right car as they were no1 on the list, but yes, as said, the photo is correct and they came with the washers as standard
    AndyParker's Avatar
    Aug 2012
    Cardiff
    164
    Thanks Guys - most helpful!
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,163
    Open the bonnet. Look beside the headlight unit. If xenon there will be a box like thing the wiring looms plug into, plus a warning sticker of HIGH VOLTAGES. Plus they have the typical audi part number on the box.
    Most likely the pic is of a xenon unit but than again my TT has projector lamps likes these and washer cut outs in the bumper, but it's fitted with standard halogen lamps.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    277
    Xenons have always been standard on the S3. Xenons and Climate are two of the very few things that are.
    Mar 2012
    298
    Quickest way is to look at the light switch - no thumb wheel next to the switch if xenon - because they are auto-level
    Mar 2007
    Cambs
    471
    Hmmm thats a bloody good point, the other day I met with another forum member and he pointed out that my car, which has adapitive Xenon plus, should as standard have auto and get me home lights, it does not :/ and also im sure next to the DRL switch it has a light leveller...
    Before I even went and saw the car I called Audi and they listed the factory extras, it was a long list, but they said adative Xenons, im not feeling a little concerned as to why it doesnt have the auto/get me home lights, and, may have a level adjuster, its in the garage again so I cant go and check but this has got me thinking!
  1. Retro fitting xenons question
    By maars in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2008, 23:25
  2. Xenons - Question for owners, which lights operate
    By mattandrew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2008, 22:09
  3. noob harness question yet again.
    By n13nhb in forum In-Car Entertainment
    Last Post: 5th November 2007, 23:48
  4. Xenon Question
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2007, 18:11
  5. Xenon Question
    By Daniel Vzla in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2007, 16:48
