EM TuningSky Insurance
Results 1 to 12 of 12
    Feb 2012
    37
    Alarm and no sound
    Hi all
    I have a 2007 (57) a3 sportback 170
    A neighbour came and told me my indicators were flashing,
    appently the alrm was set off for some reason (never happened before or since)
    but there was no sound of a horn
    so today i set alarm ans sat in car, i then set the alarm off by moving around/trying to open door.
    the alarm went off and there was a beeping inside the car, the indicators were flashing but no external sound at all...
    is this normal or does it have a sound /no sound option somewhere?
    regards
    bing
    May 2011
    Portsmouth
    397
    I've got a similar problem. I have an A3 2.0 TDI 2006 and noticed my alarm going off the other day. There was a siren but it was crackly and weak. Sounds like it is under the scuttle panel under the wind screen. Was going to investigate and repair / replace.
    does anyone know if its similar to the 8L design where the battery corrodes and ruins the alarm box?
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Alarm and no sound
    Yes the battery leaks all over the alarm and destroys the pcb. The alarm is in the front drivers wheel arch behind the liner in a security box. I replaced mine not that long a go.
    This is what mine looked like.
    H12 backup alarm horn problem
    Before you go to all the trouble of doing this job get the car scanned with vcds
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Feb 2012
    37
    HI
    surely if the battery was to leak all over the pcb....none of the alarm would work?
    it is just the sounder I do not have..
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Alarm and no sound
    That is just the sounder in the wheel arch
    Sep 2012
    Brum
    299
    You will find its a faulty horn mate. Changed mine on my s3 and now it's fine. 15 quid fix
    Feb 2012
    37
    Quote Originally Posted by big harty View Post
    I take it you mean the alarm horn rather than the actual car horn...as the car horn works ok.
    cheers
    May 2011
    Portsmouth
    397
    Quote Originally Posted by shariain View Post
    just seen your post. That alarm board is fubard. After the 8L you'd think Audi would make a better solution. Granted batteries don't last forever, I get that, but this, it's just bad freaking design and poor quality.
    When you do this job can you just buy the whole thing rather than just the pcb? Plug n play jobs are far more enjoyable ...
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Alarm and no sound
    I bought a 2nd hand h12 alarm horn from eBay. This is the part no. 1ko 951 605 c I got to replace 1ko 951 605 a hopefully the newer unit has had this issue resolved but I doubt it only time will tell.
    Once you get the car scanned with vcds you will find out if it is your h12 backup alarm horn that's at fault or another part of the alarm system that's causing the problem.
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Alarm and no sound
    Quote Originally Posted by Ads_AudiA3 View Post
    not this one this is one job I wouldn't want to do again.
    The job it's self is easy but just a major pita.
    May 2011
    Portsmouth
    397
    I've done a search online but can't seem to find any advice on this. I'm assuming it's the security box that is a pain to get into.
    Can you give me any headstart as to what to expect?
    Found a unit on eBay, apart from has D at the end instead of C ?
    Need to buy VCDS or get the car scanned tbh though, missing being able to scan my car :-(
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Alarm and no sound
    The job is easy just a pita.
    Remove front drivers wheel
    Remove inner wheel arch liner this was the worst bit trying to maneuver this to remove it. Also while this is out you might want to take out the 5kg of mud and **** that has collected behind it.
    Now if you have a look up towards where the indicator is on the inside you will see a steel box that has been riveted on. I didn't remove the rivet I just pulled the box in such a way that the tab at the back of the box that goes into the wheel arch came loose then I just turned the box to give me access to the h12 backup horn which is plug and play.
    Check operation before putting the car back together.
    Refitting in reverse because I didn't remove the rivet the box takes a bit of manipulation to get back in as tight as it was but it's possible.
    There were no special tools required just a lot of self control.
  1. Replies: 5
    Last Post: 12th March 2010, 10:42
  2. ALARM AND KEY!
    By durk in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2010, 16:25
  3. Replies: 7
    Last Post: 23rd March 2008, 12:09
  4. Alarm and immobiliser
    By JeffY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2006, 23:18
  5. audi alarm and immobiliser.
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2005, 21:59
