Hey guys i got round to fitting my 2009 dash the other day and asked my friendly audi master tech friend code my key for me after we were done i went back to work (VW garage) to code everything up however after reading NHN'S guide i realized i need a little help from you guys if you'd be so kind i don't have access to vcds only vas 5051B,2,6150a etc.
So what I did, I went home, plugged in VCDS, went into 17, security access to which vcds prompted me to enter a certain code that was displayed, entered, went into adaptation channel 37 & set to 11 given mines 2wd where as 4wd is 00 I think, but quick browse in there can advise which is correct for your car, this told car what braking systems etc I had, lights all went out, job done.
i was wondering if anyone out there could post the certain code for 2009 dash so at least i can try it as i have a feeling they are the same across the line like abs access code 40168 isn't vehicle specific i was wondering if it was the same as the one on ross tech of 13861 many thanks in advance
