JMB RetrofitsBadger5
    Jul 2012
    44
    thrust bearing Q!!
    ok all
    right my thrust bearing on the clutch has started to make a noise when putting my foot halfway down on the clutch pedal.
    what are my options with this,new clutch or can i just get the bearing done without the clutch being changed.
    2005 2.0 tdi 140 sportback.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Its a concentric slave, you can replace it without changing the clutch but you'd be daft not too as the box needs to come off to change the slave so you may as well do the clutch whilst at it.
    Jul 2012
    44
    damn only had the car 2 months and this has happened,how much would i be looking at if i was to change the clutch ?
  1. IHI Roller bearing turbo
    By RichA3Turbo in forum The Project Room
    Last Post: 14th August 2009, 11:52
  2. thrust bearing?
    By easytease in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th December 2005, 09:30
  3. Just had bearing arms replaced - FORKED OUT!!
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th August 2004, 20:52
  4. Wheel Bearing (Spelling?) noisy
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2004, 17:34
  5. Funny noises from my S3 (Wheel bearings?)
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2003, 09:45
