JMB RetrofitsChris Nott
Results 1 to 7 of 7
    Pez
    Aug 2012
    22
    Upgrading a double din chorus
    I've just bought an 09 plate A3 sportback that has a double din chorus stereo.
    I've been googling for ages trying to find out my options for upgrading but most of the info seems to relate to concert or symphony units.
    What I want is bluetooth (for talking, not music), ipod connectivity and possibly sat nav.
    I don't have a multi-function steering wheel or driver information system, so presumably this will make things a bit less complicated.
    I'm happy going with an aftermarket unit if it makes things easier. Or if I go with a rns-e unit will it be plug-and-play?
    Any advice would be appreciated.
    Mar 2011
    Cleveland
    996
    The rns-e is plug and play. Just search for retrofits and you'll find everything. I've just finished mine.
    Jan 2012
    1,837
    Not having a MFSW and DIS will make things MORE complicated
    Pez
    Aug 2012
    22
    Well I've been searching and searching and still can't find much that relates to the chorus...
    A6CR - why would it make it more complicated? Do you mean for aftermarket or rns-e? Or both?
    If I stick with the chorus, can I add an ipod connection to the glovebox? Or would I have to change to a concert head unit first? I'm not that fussed on having back speakers, I'm happy to stick with the two front door ones and the tweeters.
    Apr 2009
    46
    I've recently put in an double din Alpine unit (CDE-W235BT) into my A3 s-line which sorted the phone and music from my iPhone perfectly. All Bluetooth. Very pleased with it.
    Pez
    Aug 2012
    22
    Quote Originally Posted by KevinF View Post
    Was it easy putting in that Alpine unit? And was it replacing a chorus? Think for the difference in price I'd rather have one of those!
    Apr 2009
    46
    Unit cost 210. Shop fitted it for 30 but needed a few extra wires/connectors/adapters etc. Came to 300. I think I had the Concert - whatever is standard in the A3. Arn't all double dins the same size? Sound quality is excellent.
  1. Single din concert to double din chorus
    By JPK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2012, 01:40
  2. Upgrade to double din?
    By tam2oo5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2012, 23:08
  3. Chorus Single Din to RNS-E Double Din
    By stevereid in forum Satellite Navigation
    Last Post: 26th July 2010, 19:20
  4. double din upgrade
    By chris a4 128 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th July 2008, 00:27
  5. A4 8E Single to Double Din Upgrade
    By A6QuattroDriver in forum In-Car Entertainment
    Last Post: 7th November 2005, 19:51
