RNS-E upgrade
timontour
NULL
I'm thinking about changing my concert for an rns e, from what i've read seems pretty straight forward as it's double din
only thing is my cars got a parrot fitted will this effect thr rns-e? also mine has a multifuction steering wheel is this just a matter of coding it with VCDS?
thanks in advance!
Sounds like a direct swap ! Just ditch the Parrot and code the rnse with VCDS. However, you will probably need the Audi bluetooth unit to get phone functions to work properly.
You will be fine with the Parrott kit mate. RNS-e will just need to be coded correctly with VCDS.
Although if you want full functions of your phone through the MFSW and DIS as well as the RNS-e, then as Mike suggested, go for the OEM Bluetooth and get rid of the Parrott.
cool thanks for the reply's, i have VCDS but not too sure on the coding side i will fit it then scan for errors and see what comes up
