Volks AutosMonster Motorsport
Like Tree1Likes
  • 1 Post By pwilliamson1991
Thread: Please help problem with Audi a3
    Jan 2012
    I'm really hoping someone can help me with a problem that has just occurred with my car.
    car is a 2005 audi a3 2.0t.
    i was driving along and all of a sudden the traction light came on and as did the abs, the brakes were none existent and my brake pedal travel was all the way to the floor to get what little braking I had left, also the car has devolved a grinding noise and from what I can see there is excessive wear on my passenger side brake disk, the grind is constant but does seem to get worse if change direction.
    if anyone could help me out I'd be very helpful before I have to go to Audi stealers.
    Thanks Stu
    pwilliamson1991's Avatar
    Aug 2012
    UK
    76
    Regarding "traction light came on and as did the abs, the brakes were none existent and my brake pedal travel was all the way to the floor to get what little braking I had left"
    Sounds like you may have blown a valve along the break line. This can happen and basically it means your break fluid comes out of the system. Have a look around your wheels to see if you can see break fluid on any. Also check your break fluid level. This has happened me before exact same symptoms. The cost to get this fixed is relatively cheap as you just need a new valve and some new brake fluid to replace whats gone. If its clear this is the problem I recommend not going near audi a local garage could fix this for half the price.
    Regarding the grinding noise I'm not sure. Obviously sounds like your pads are worn but this would have no link to what I discussed previously.
    If in doubt best to fork out and let the experts have a look.
    rmstu likes this.
  1. numerous problems with audi A3, help needed
    By Tripp in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2012, 16:46
  2. PLEASE help problem i have with A5 Alloys for A4 2008
    By lochandubh07 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th June 2011, 21:48
  3. Strange problem with Audi 80
    By lucyandpeter in forum Classic Audi Forum
    Last Post: 2nd March 2006, 20:58
  4. Help - Problem with brakes
    By imported_AndyB40 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th November 2005, 09:31
  5. Please help me with an A3 door problem.
    By JeremyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2004, 06:17
