Chris NottJMB Retrofits
Results 1 to 8 of 8
    Jun 2012
    Orpington Kent
    32
    Audi A3 3.2 v6 2004-5 Timing chain help.
    I've have had a problem with me motor an from what I can tell its the timing chain tensioner. I have done stuff like this before just not on this engine an want to get it right. am I looking for as much info to do it myself pictures, torque settings, tips what too look for what Not to do.
    I will not be changing the chain as know its quite new, just the last person did not fit right i guess as hence the issule i have.
    Would also be happy drive the car an do there if someone was offering to help. am open too help! times are hard!
    Spider's Avatar
    May 2011
    50
    Loads of stuff on the R32 forum
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,203
    There are 2 tensioners on the 3.2, one is on the back of the engine and is a simple job to unscrew, the other is much more difficult to get at and will involve a lot of stripping down again.
    Do you know exactly what was replaced? When I had mine stripped down, everything was changed that was connected with the chains including the vvt's and chain guides, never missed a beat after that.
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    Jun 2012
    Orpington Kent
    32
    i dont know. I just know it was changed before i got the car, an can see the chain has been touched, also shows its reading as tight, so guess was not done correctly. striping down should not be a problem, just need know what to look for.
    Saying loads of info on r32 fourms dont help, i dont have 4-5 hrs to look throu all this. im quite a noob when come to using forums. sorry.
    Guess it would be best to start with the easy one. the computer reports says MVB 208/209 checked -1 camshaft on 7.0kw
    Jun 2012
    Orpington Kent
    32
    Any noob help / guild for checking the easyone?
    Spider's Avatar
    May 2011
    50
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Lol that's my DIY guide :-)
    Spider's Avatar
    May 2011
    50
    Quote Originally Posted by RobinA3 View Post
    :D
  1. Audi A4 3.2 Quattro s-line cabriolet Timing Chain Noise
    By darrenparrott in forum The Welcome Section
    Last Post: 24th June 2011, 16:27
  2. Audi A4 3.2 Quattro s-line cabriolet Timing Chain Noise
    By darrenparrott in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th June 2011, 06:45
  3. ARB and timing chain - at only 36k ???
    By Amchlolor in forum TT/TT-S/TT-RS Forum
    Last Post: 16th August 2006, 15:46
  4. timing chain tensioner
    By stebed in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th May 2004, 17:02
  5. 2.8 Timing Belt or timing Chain ????
    By RichbagggA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2003, 07:10
