Chris NottVolks Autos
    Oct 2012
    New Forest
    A3 2.0tdi - leak from fuel pump & diesel in engine bay
    Picked up an A3 2.0tdi on Monday and it has a fuel leak from the top of the fuel pump under the bonnet.
    This has led to fuel splashing all over the engine bay - car is back at the garage I bought it from (a Merc main dealer) to be sorted.
    Am I right in thinking the auxiliary belts will need replacing as they will have been contaminated with the fuel?
    I'll obviously expect them to steam clean the engine bay & anywhere else covered in diesel.
    Anything else I shoul dbe getting them to do / check?
    Thanks.
    Jul 2012
    194
    Are you sure any gaurantee's haven't already run out.
    Oct 2012
    New Forest
    Dealer has just called and said they have replaces O ring on the fuel filter and are going to keep it over night & give it a run to check it has solved the problem.
    They have also steam cleaned everywhere.
    Mar 2012
    Somerset
    22
    So is it the fuel filter or fuel pump that was leaking?
    I had the high pressure pump gasket go and that was leaking diesel and making the car smell awful.
    The gasket cost under a tenner and its about an hours labour.
    Oct 2012
    New Forest
    I thought it was fuel pump, but maybe fuel filter is on top of fuel pump?
    Front left of engine bay next to the washer bottle, has 4 (IIRC) pipe going into the top.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    That's the fuel filter.
    VCDS USER
  1. fuel pump or boost leak?
    By tonks s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2012, 14:34
  2. Ticking on 1st ignition, could be from the fuel pump??? Help
    By haytch75 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th June 2011, 16:19
  3. Underfueling and noise from the fuel pump
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2010, 14:58
  4. leak from fuel tank
    By paul_s4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th May 2010, 11:50
  5. Revo Stage 2+ with KMD fuel pump internals from JBS
    By warren_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th August 2009, 17:28
