Monster MotorsportVolks Autos
Results 1 to 27 of 27
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    Multi function steering wheel
    Would anyone know if a direct replacement, what extra parts need to replace my wheel
    my current p/n 8P0 419 091
    change to 8T0 419 091
    I have vag-com to enable the multifunction but will it require any wireing or modules?
    thanks
    Fossie
    Rhubarb Triangle
    3,969
    What year car do you have and what is the part number of the steering ecu. ?
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    A3 sportback 2.0TDI 54 plate
    Steering wheel controller 1K0 593 549 A
    Current soft coding 0000012
    Fossie
    Rhubarb Triangle
    3,969
    You need a Highline DIS ( split into 3 sections ), a steering controller 8P0 953 549 F and slip ring suffix 'D'. for the mfsw to work.
    You will also need to ensure that your existing airbag fits the new wheel and that your car is already fitted with a two stage airbag system.
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    Bugger! Might have to rethink that then
    thanks anyway
    Aug 2012
    13
    Hi Guys,
    I dont want to start another MFSW thread.
    My car is 2008 S3 Sportback facelift car and i had S3 steering wheel no multifunction. I wanted to have RS steering wheel so i bought new one with 8J0 419 091 code - pls see picture. I also bought used airbag but i dont have part# - the guy asked me for my steering wheel picture and number and he said this airbag should be good.
    From what i've read i need 8P0971589Q cabling to connect steering wheel and airbag and then i need 1K0959653D clockspring and also new module 8P0 953 549 F, as according to VAG software i have 1k0 953 549 AH.
    Can you please confirm that i need to purchase all 3 above items to get it working for my S3?
    Currently i lost steering assistant and driving is very difficult and ESP airbag faults.
    Much appreciated for your help!!!
    Fossie
    Rhubarb Triangle
    3,969
    You will need the cable you mention although the part # with suffix 'Q' may now be superseded. Audi will give you the correct one for mfsw.
    You will need the steering module you mention --- 8P0 suffix 'F
    I think you will already have the correct slip ring (suffix D) because that was usually fitted with the steering module that you already have.
    After installation you will need to carry out steering basic settings and code the wheel with VCDS to get steering assist back and then all lights will extinguish.
    Just be sure that the 'used' airbag has not been deployed and is still intact. If you paid less than about £150 - £200 for it then it is likely to be 'dodgy'.
    Aug 2012
    13
    Hi Mike,
    Airbag is intact and was never fired up - im pretty sure it works correctly,just hope it will work with all electronics. Unfortuantely my steering sensor might been damaged as i havent replaced it or secured it after i changed the steering wheel. We also tried diagnostics with VCDS and when i moved the steering right / left the sensor didnt show any movement and that might be the cause why i lost steering assistant. I guess i'll get all three items and i should be able to conenct everything and get everything working.
    Is there a chance that my steering angle sensor is still working or its already damaged?
    thanks!
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Hi fella, I have a steering angle sensor if interested. Can sell for £15 posted.
    PM me if interested. I also have a slip ring available.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Fossie
    Rhubarb Triangle
    3,969
    It's unlikely to be damaged. The slip ring and steering angle sensor are in the same unit but you need to carry out the basic settings with VCDS to get it to work.
    check the RossTech site for instructions.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    If you can post a copy if your scan, then we can see the fault codes and point you in the right direction.
    It is most likely what Mike has said, and probably needs basic settings and adaptation preformed.
    Aug 2012
    13
    My logs below:
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
    Component: ESP MK60EC1 H35 0104
    Revision: 00H35001
    Coding: 14428012092600FC281401ED901D00413800
    Shop #: WSC 06314 000 00000
    VCID: 75E5E5E760E5
    3 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 50
    Mileage: 74691 km
    Time Indication: 0
    Date: 2012.10.01
    Time: 07:50:54
    Freeze Frame:
    Count: 2
    Count: 2
    Count: 12800
    Count: 294
    Count: 42496
    Count: 0
    Count: 0
    Count: 0
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 51
    Mileage: 74699 km
    Time Indication: 0
    Date: 2012.10.01
    Time: 08:05:25
    Freeze Frame:
    Count: 2
    Count: 32768
    Count: 12800
    Count: 8193
    Count: 49722
    Count: 0
    Count: 0
    Count: 0
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 11
    Mileage: 74666 km
    Time Indication: 0
    Date: 2012.09.30
    Time: 06:26:27
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12800
    Count: 295
    Count: 45312
    Count: 57856
    Count: 0
    Count: 0
    oraz
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 234 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A5F069BF9DB
    3 Faults Found:
    16353 - Control Module - Internal Malfunction
    014 - Defective - MIL ON
    Freeze Frame:
    Fault Status: 11101110
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 2
    Mileage: 74323 km
    Time Indication: 0
    Date: 2012.06.09
    Time: 01:39:15
    Freeze Frame:
    Battery Volts: 11.7 V
    DU
    Temperature: 27.0∞C
    Error Code: 14745
    Torque: -6.8 Nm
    Torque: -2.304 Nm
    RPM: -2388 /min
    00573 - Steering Torque Sensor (G269)
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 10
    Mileage: 74700 km
    Time Indication: 0
    Date: 2012.10.01
    Time: 08:08:01
    Freeze Frame:
    Battery Volts: 12.2 V
    DU
    Temperature: 34.0∞C
    (no units): 65
    (no units): 32
    Torque: 0.0 Nm
    Count: 837
    02391 - Terminal 30 Reference
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.88 V
    PD
    Temperature: 34.0∞C
    Speed: 50.0 km/h
    Torque: 0.0 Nm
    Torque: 0.000 Nm
    Term 15 On
    Mar 2007
    Cambs
    471
    On this subject, mines has a mode button and a button with arrow pointing left, when I push either it says...no function
    What are these for?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Cossie_boy View Post
    What are these for?
    The arrow button only works with Audi Bluetooth phone connection installed. The mode button only works with RNSE installed as far as I know !
    Mar 2007
    Cambs
    471
    Mines an 08 so guessing it doesnt have that then, are those boxes plug and play?!
    Fossie
    Rhubarb Triangle
    3,969
    Not without additional wiring and coding. If you don't have double din radio then all sorts of additional bits are needed as well !
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Mario, silly question but have you tried to clear these faults?
    Anyhow, if you check all the links i have provided from Ross Tech, they give possible causes and solutions to your fault codes.
    Fault code 01826 01826 - Ross-Tech Wiki
    Fault code 01314 01314 - Ross-Tech Wiki
    Fault code 00778 00778 - Ross-Tech Wiki
    Fault code 16353 Can't seem to find a fault code related to this on Ross Tech
    Fault code 00573 00573 - Ross-Tech Wiki
    Fault code 02391 Can't seem to find a fault code related to this on Ross Tech
    This is the best i could at the moment mate, see how you get on with the possible solutions in the links.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    You are half right Mike.
    The arrow button is used for voice control used with oem bluetooth and also SDS versions of the RNS-e.
    The Mode button is used to switch between your phone book and radio on you DIS, which works with RNS-e, Chorus, Symthony etc, but you still need to have the bluetooth installed for this to work.
    Without bluetooth, then these are just dead buttons.
    Fossie
    Rhubarb Triangle
    3,969
    Thanks Danny - it's a long time since I researched the subject and, as I do not have rnse installed, the detail had faded somewhat !!!
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    No problem Mike. But you more than make up for with all the time and effort you put into this site to help others. Your a credit to this site mate, and many will agree.
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    New wheel fits... Airbag fits new wheel, has two wires, so two stage I guess?!...
    how can I tell if I have a 'Highline' DIS?
    Then just need the module and slip ring..... Also a new cable to connect slip ring to the wheel controls/airbag?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Quote Originally Posted by Boon View Post
    you already have the dual stage airbag system being a sportback.
    Also no need for a new slip ring as your current one will be fine. Yes, all you need now is the wiring loom, the correct steering module (8p0 953 549 F) and a bit of VCDS coding.
    Out of interest, have you physically checked the airbag fits? Because the part numbers you provided in your OP suggests that your current airbag will not fit the 8T0 wheel as they are different fitments.
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    Quote Originally Posted by Dannykn9 View Post
    Great, many thanks.
    I took a chance that even if it wouldn't work I'd have a new wheel to use or sell!
    Yes the airbag fits... New wheel and original airbag have been fitted to car for a few weeks now, just want the controls to light up and use the volume as the RNS-E volume knob needs a clean inside (volume often goes up when turning down!)
    On the lookout for a module now then
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    Would anyone know if steering control module 1K0 953 549 F will work or do I need 8P0 953 549 F?
    Is there any difference?
    Fossie
    Rhubarb Triangle
    3,969
    Sorry mate, it will not work. You need a 'highline' control module and type 2 slip ring for mfsw.
    See here for more info about 1k0 modules :- Steering Wheel Control Module Versions - Ross-Tech Wiki
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    MFSW only works with the 8P0 module!
    I may have one for sale.. just waiting to hear from the customer who wanted it... if he doesnt get back to me then its going to go back for sale
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
  28. #27
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    Ok so
    Steering module 8P0 593 549 fitted and new harness 8P0 971 589 AD
    The buttons dont do what they are ment to... They light up... But...
    The left wheel when pressed in turns up the volume... The right wheel when pressed turns down the volume...
    The Mode & Voice buttons turn the tracks!
    Had noticed that the wires do not match up...
    Wheel end Pin 1 - Black, Pin 2 - Yellow, Pin 3 - Red
    Harness Pin 1 - Blue, Pin 2 - Red, Pin 3 - Black
    I tried repinning to match Black to Black, Red to Red & Blue to Yellow but nothing worked at all
    Is there a way to repin or recode something so they work as they should?
  1. Retro Fitting Multi Function Steering Wheel?
    By Von Maximo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2007, 18:30
  2. Parrot CK3000 and Multi-function steering wheel
    By Tipster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2007, 21:48
  3. A3/S3 multi-function steering wheel
    By 4SilverRings in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2006, 05:18
  4. Multi Function Steering Wheel
    By maz1975 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th September 2006, 15:26
  5. Multi Function Steering Wheel
    By ldw in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2006, 11:54
