Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Jun 2010
    40
    Rear passenger side footwell water/rear washer jet (I HAVE SEARCHED)
    I've been searching for the past hour and still haven't found an answer to my problem!
    In the rear passenger footwell, by the outside mat fixing peg thing, right in the corner its damp/wet.
    It's not so much of a pool just very very damp.
    I'm looking for the info on where the rear washer pipe runs through the car, as this also doesn't work; although the pump makes the right noises!
    I've had a look about under the car, around the door etc and i can't find anything else that seems to be wet!
    If i could find out where the rear washer pipe runs, i'm pretty sure it's going to be that!
    leach76's Avatar
    Feb 2009
    sheffield
    304
    The washer pipe runs down the drivers side,is the front damp at all ? as in not coming through the pollen filter area and running through to the back,then there is things like sunroof drains ,lamp seals,door seals,wiring grommets
    Jun 2010
    40
    I'll tomorrow morning!
    Go do I see if its coming through the pollen filter etc?
    i can't even see how to get the trim off to get under the carpet!
    Jun 2012
    Redhill Surrey
    629
    Add Grale1 on Facebook
    Can't help you with the damp, but I had the same problem regarding the rear washer jet not working, I just took of the plastic top and took the bit where the water comes out and put a pin in the bottom and the top, mine had little bits of dirt or something that was stopping the water coming out,
    nevergivup99's Avatar
    Feb 2011
    27
    I had a similar problem with my 3 door, water in the boot, around the spare tyre and under the rear seat I was convinced it was the valet in work, using a high pressure cleaner, I checked if the water was entering via the lamp clusters, the rear washer, the petrol filler, even the roof aerial, but by testing and elimination I found it was the rear hatch seal and nothing at all to do with the valet. I replaced the seal, which cost about £35 and it has been as dry as a bone since.
    Jun 2010
    40
    Ok, i've finally got round to stripping out the back of the car, and taken some pictures.
    I've located where the water is actually coming in, but can't figure out how its getting there.
    These are the pictures i've got so any help on where its coming from would be mega helpful!
    Bottom of the door, have a feeling this little hole might be something to do with it? Any Ideas?
    http://i45.tinypic.com/35ib2a0.jpg
    Behind the seat and can see where its wet, guessing its running down by the golden nut and into where its pooling, as you can see by the dark patch.
    http://i46.tinypic.com/2z6xhn4.jpg
    This is just a picture of the area, its the bottom right where the water is coming in.
    http://i50.tinypic.com/330gpvn.jpg
    Jun 2010
    40
    Right, i've just been out to drive through some puddles too, and its not coming from below.
    So something must be letting it in from above.
    May 2012
    West Country
    172
    As an Ex Skoda MK1 Fabia owner I have a theory that it is the ancillaries
    carrier behind the doorcard that is leaking. The Fab is notorious for this.
    I've had 2 of 'em and had to re-seal all the doors on both of them.
    If the construction method is the same (since they are both VAG cars) then
    I'd look there first. On the Fabia at least they are designed so that the
    door allows rainwater to literally pass through the door and out of drain
    holes at the bottom and onto the sill. (Stupid design IMO)
    The ancillaries carrier is riveted to the door with a foam tape seal between
    the two pieces. This is what usually fails on the Fabia. It can be replaced
    but it's probably easier to use a thick bead of sealant to stop it rather than drill
    out all the rivets and replace the thing that failed with another just like it.
    Bituminous gutter sealant was the best thing to use on the Fabia as it adheres
    to wet surfaces. Under no circumstances use ordinary silicone sealant, it won't stick
    to wet surfaces or the zinc plating of the door carrier. It must be either Plumbers Gold,
    Shell Tixophalte (My preferred choice since I have a few tubes laying about) or a similar
    bitumen based sealant.
    If you need any more info on the Fabia leaks then check out Briskoda.net as they have
    a few active threads on the subject at the moment what with all this rain lately.
    It has been covered over there at great length, it happens to nearly all Mark 1
    Fabias sooner or later. Assuming the setup is the same with the A3/S3 it may be
    worth having a look over there for more tips and info on the fix.
    2009 S3 3 door. Phantom Black metallic.
    RNS-E, Tints, Piano Black inlays, Auto Lights and Wipers, Bluetooth, MFBSW,
    White Alcantara, LED numberplate lights, Black Optic Grille, Yellow Foglamps,
    K&N panelfilter, Colourmatched mirrors, S3 footplate,
    More to come....
  1. Strange clung (Pong) from rear passenger side of car. Any ideas??
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2011, 18:19
  2. Water in footwell + rear washer jet not working + aircon knackered
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2011, 14:57
  3. S3 passenger seat/rear washer jet problem
    By zseth in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2010, 13:19
  4. Water in the Rear Passenger footwell
    By jPwatts in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th April 2009, 20:58
  5. Water in rear passenger side foot-well !!!!
    By CO11K9 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th December 2008, 17:51
