Chris NottSky Insurance
    Sep 2012
    2010 s3 wheel offset range
    I need to buy winter wheels and tyres as my s3 and me are in Oslo this winter. My current rim size is the factory supplied 18"x7.5j ET54.
    Can someone tell me what range of offset I can get away with? e.g. would a ET35 fit or can I go no lower than ET45 for example?. I'm planning on buying secondhand (as there are loads for sale here) and clearly this is important.
    Also can I go smaller than 18" rim i.e. 17" or even 16"?
    Jan 2012
    SW London
    751
    Dont think id get anythin less than an 18 over ur brakes. 345mm i think. As for offsets again i think its a case of clearance for the huge brakes. But ill wait for someone to confirm
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Feb 2009
    Aberdeen
    2,489
    I think 17s will fit over the S3 brakes, but 16s won't. And ET range will vary with the wheel's width (you'll get a lower ET 7" on than an 8.5"). ET45 is probably a good target to work with to avoid any issues, and down to 40 will liekly fit on an 8" or narrower. Talk to N8, he'll know for sure. Or find a wheel you like and get the specs, then he'll be able to tell you if it'll fit.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    K13 ASJ's Avatar
    Aug 2011
    Buckie (north east scotland)
    176
    mines 18x8 et42 and they sit pretty flush with the arches with no spacers.
  1. 8J 18 wheels offset 32 with 235/40R18 tyres - will this be OK on 2010 S3?
    By Braveheart in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2012, 16:20
  2. Wheel offset
    By QuantumJohn in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th December 2004, 17:16
  3. Wheel Offset Problem??
    By hitby in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th December 2004, 08:43
  4. Wheel offset
    By AndyC in forum General Technical / How To
    Last Post: 5th December 2004, 17:05
  5. What wheel offset?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2004, 11:27
