Sky InsuranceChris Nott
    Sep 2012
    2010 s3 wing mirror glass replacement
    Would you adam and eve it, some toe rag tried to remove the glass from my wing mirror with a screwdriver and only succeeded in shattering the glass!
    I have the replacement but realised, if a thief couldn't get the current one off, how do I?
    Does anyone have any advice on removing wing mirror glass, is their a "how to do..." link somewhere?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,333
    Try the link below. Post 3. Welcome to audi-sport.net. Where are you located? Any pics of the car? x
    Removing Wing Mirror Glass
    Sep 2012
    Thanks Sandra, sounds easy. Pics of car soon, it's also a "Black Edition." I'm actually in Oslo and having a nightmare finding second hand winter wheels/tyres that will fit; the callipers are too big for 16" wheels which seems to be the only things for sale on the second hand market over here!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,333
    ​Have a look in our classifieds section. Use the advanced search to narrow your search down. x
    27,014
    Lean the mirror all way forward from the top, get some fingers behind top center, spread evenly across the area & slowly with even pressure, apply to this area & it will pop off, dont rush it, take your time & when fitting new one again push in the middle with even spread pressure with flat of hand.
  1. Replace wing mirror glass - 1600 A3 4-door Technik Dec 2010
    By spantik in forum General Technical / How To
    Last Post: 14th July 2012, 16:50
  2. WING MIRROR GLASS REPLACEMENT
    By marktdisport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th December 2011, 16:26
  3. 2002 S3 wing mirror glass - replacement other than Audi
    By bpascua in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2011, 11:48
  4. Replacing Wing Mirror Glass A3
    By Audilee in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2009, 22:46
  5. where can i buy replacement wing mirror glass?
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th June 2006, 22:51
